received an API command message with an invalid JSON payload
Mon Mar 13, 2023 7:05 am
Vaillant offline
Hello,
I use the app BetterTouchTool and this works:
do shell script "curl --digest -u 'USER:PASSWORD' http://192.168.1.14:8176/actions/Remote_Buddy_Menu?_method=execute"
The app is preventing the use of double quotes inside the do shell script.
Trying:
do shell script "curl -X POST -H 'Authorization: Bearer API-KEY' -d '{'message': 'indigo.actionGroup.execute','objectId':1573095203}' 192.168.1.14:8176/v2/api/command"
It gives me the Web Server Error and Web Server Warning HTTP 400 error for request /v2/api/command from 192.168.1.14
The App returns with {"request_body":"{message: indigo.actionGroup.execute,objectId:1573095203}","error":"invalid JSON"}
I tried all kinds of variations with the use of quotes but nothing works.
Who can help.
Greetings, Adrian
Mon Mar 13, 2023 8:34 am
Re: received an API command message with an invalid JSON pay
JSON doesn't allow single quotes to be substituted for double quotes, and AppleScript doesn't allow the opposite. So, you have to construct your command line using escapes:
do shell script "curl -X POST -H 'Authorization: Bearer API-KEY-HERE' -d '{\"message\": \"indigo.actionGroup.execute\",\"objectId\": 64217936}' http://YOUR-IP-ADDRESS:8176/v2/api/command"
I suspect that you don't need to do it from an AppleScript though since I'm pretty sure that BetterTouchTool will also do shell scripts so it might be possible to just do the curl command directly (but I'm speculating since I don't use BTT).
Mon Mar 13, 2023 11:31 am
Vaillant offline
Thanks Jay, that made it work again.
You are right about BTT doing shell script.
I tried it but works slower then applescript.
I use BTT with a Siri Remote.
First impression is that the new HTTP API is less snappy then the old way!
I will keep monitoring. Ik hope I get back the snappy responce times.
Maybe there are some tips to speed things up?
Mon Mar 13, 2023 2:21 pm
It should be faster - the new web server we're using is significantly better than the old one (which all of our testing shows), so I'm not sure why it would be slower for you.
Wed Mar 15, 2023 4:01 am
Vaillant offline
Testing the slow responce but no change.
Using 2022.2,-> button press, results is a 1 second delay.
Using 2022.1 -> button press is an instant reaction
Tried it several times and the outcome is always the same.
Using applescript or shell script from BTT makes no difference.
Using Terminal on the host or other mac to test and still a 1 second delay.
macOS 10.15.7
MacMini (late 2012)
BTT and and indigo server are on the same mac.
Wed Mar 15, 2023 12:53 pm
How exactly are you sending the old command and the new command? Copy/paste the code/url/whatever for each (remove any credentials).
Also, when you go to the new Indigo Touch for Web interface, is there any delay when you turn on/off the same device?
Wed Mar 15, 2023 1:39 pm
Vaillant offline
2022.1 instant action with
    do shell script "curl --digest -u 'USER:PASSWORD' http://192.168.1.14:8176/actions/Remote_Buddy_Down?_method=execute"
2022.2 1 second delay with
    do shell script "curl -X POST -H 'Authorization: Bearer API-KEY' -d '{\"message\": \"indigo.actionGroup.execute\",\"objectId\": 1673871159}' http://192.168.1.14:817/v2/api/command"
Web interface is instant action
Wed Mar 15, 2023 1:57 pm
And what exactly does "Remote Buddy Down" do?
Wed Mar 15, 2023 2:18 pm
Vaillant offline
I use a Siri Remote with BetterTouchTool.
On buttonpress it executes the actiongroup 'Remote_Buddy_Down' in Indigo.
It in turn toggles a variable 'Down' between true/false.
A trigger checks the change and depending on a scene (watch TV, Listen music, watch movie) it sends a command to a specific device.
I could replace indigo.actionGroup.execute in the curl command with a variable action to test if there is any change in response time.
But I don't know if there is a command in HTTP API to toggle a variable.
Thu Mar 16, 2023 9:16 am
We are adding some caching features in the next maintenance release (2022.2.1) which we believe will speed up some API calls.
Fri Mar 17, 2023 7:41 am
Vaillant offline
I did a clean install and made a fresh user account to rule out that anything was interfering.
Still getting the 1 second delay with the HTTP API.
If you want me to test something please let me know.
Hoping the next release comes soon.
In the mean time I will revert to 2022.1 till there is a solution.
Fri Mar 17, 2023 4:00 pm
Yes, we are pretty sure this will be addressed in the next bug fix release of Indigo.
Tue Apr 04, 2023 3:16 pm
This should be addressed in the just released 2022.2.1 release.
Wed Apr 05, 2023 10:33 am
Vaillant offline
Issue is solved.
Response time is back to normal with 2022.2.1.
Wed Apr 05, 2023 4:32 pm
Great, thanks for the confirmation.
