Confused a bit - RESTful API -> json / new webserver
Tue Feb 28, 2023 1:26 pm
shapa offline
For many years I've been using my intercom (2N) to trigger some functionality via Indigo when someone calls at the door - a simple HTTP call via built-in automation.
Now it's not working because of deprecated RESTful API.
I'm trying to re-enable the feature. Authentication works OK, but I'm confused with payload a bit.
What should I put in the "text" field?
The URI is "http://172.16.1.100:8176/v2/api/command?api-key=xxxx" (works ok)
The text is {"message":"indigo.variable.updateValue","objectId":'1208039266',"parameter":{"value":"True"}}', which is not working.
Web Server Debug received an API command message with an invalid JSON payload:
Web Server Warning HTTP 400 error for request /v2/api/command from 172.16.1.26
Screenshot 2023-02-28 at 19.22.39.png (320.27 KiB) Viewed 1082 times
Tue Feb 28, 2023 1:38 pm
Re: Confused a bit - RESTful API -> json / new webserver
"parameter" should be "parameters". But there's also an issue with your quotes (the single quote on the end). It should be:
  "message": "indigo.variable.updateValue",
  "objectId": 1208039266,
  "parameters": {
    "value": "True"
Instead of:
  "parameter": {
    "value":"True"
You may also need to surround the whole thing with quotes depending on your software.
Tue Feb 28, 2023 2:08 pm
shapa offline
Fascinating, as I've taken the "parameter" from the official docs
https://wiki.indigodomo.com/doku.php?id ... n_examples
Thanks, I will try now.
Tue Feb 28, 2023 2:23 pm
shapa offline
Neither with nor without quotes
Web Server Debug valid access token/api key...
Web Server HTTP API command call received from 172.16.1.26
Web Server Error received an API command message with an invalid JSON payload
{"message":"indigo.variable.updateValue","objectId":'1208039266',"parameters":{"value":"True"}}
'{"message":"indigo.variable.updateValue","objectId":'1208039266',"parameters":{"value":"True"}}'
Tue Feb 28, 2023 2:28 pm
Please try this one specifically:
{"message": "indigo.variable.updateValue", "objectId": 1208039266, "parameters": {"value": "True"}}
Tue Feb 28, 2023 2:34 pm
shapa wrote:
Fascinating, as I've taken the "parameter" from the official docs.
Sorry, that was my typo. Dave's fixing it now.
Wed Mar 01, 2023 6:52 am
shapa offline
Works now! Thanks a lot. Quotes are the key...
Wed Mar 01, 2023 7:10 am
Good deal. Glad you were able to get it working. Single quotes in JSON are problematic. As far as I know, they can never be used for element names or value containers, and must be escaped when contained within a value. For example,
{"element": "Element\'s value."}
Please report back if you see any other issues with the API specification docs or examples.
