What is this file?
Mon Apr 16, 2018 7:02 pm
srkinard offline
What is this file?
I was looking via DaisyDisk to see what was taking up space on the Indigo server's SSD and this file is 7.9GB in size...what is it?
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/a.dump
My total folder size for /Library/Application Support/Perceptive Automation/Indigo 7/ is 24.3GB now. The a.cp file is 6.2GB, as is the indigo_history.sqlite file in the /Library/Application Support/Perceptive Automation/Indigo 7/Logs/ folder.
Just trying to clean things up...I've been contemplating moving everything to a different, newer & more powerful system...but it has a much smaller SSD. So I need to shed the excess size.
Ross
Tue Apr 17, 2018 7:59 am
siclark offline
Re: What is this file?
Ross
I think it's from Karl's utility to repair the SQL lite db. Have you used that?
Tue Apr 17, 2018 1:28 pm
Yes that’s it.
You can delete that file.
Tue Apr 17, 2018 2:41 pm
What is this file?
It’s a program script that does
1 copy SQLite current dB- dump takes too long with indigo active
2 create a dump of that file copy
3 go through dump file and fix issues
4 create Postgres file w empty indigo tables
5 convert sqldump to Postgres import
6 Import Postgres file to indigo tables
Wed Apr 18, 2018 4:59 pm
siclark offline
lanbrown wrote:
Not to get a little off topic, but you wrote a program that logs a.dump?
Thu Apr 19, 2018 8:00 am
Swancoat offline
I heard that's going to be a feature in the next version of HealthKit.
http://nerdhome.jimdo.com
Fri Apr 20, 2018 5:27 pm
Colorado4Wheeler offline
This thread has gone to crap.
Fri Apr 20, 2018 5:50 pm
I've heard it goes better when you use Google fiber. Then it really runs.
Sat Apr 21, 2018 9:22 am
Yea, that's true, you've never had a.dump as big as when you have a ton of fiber running through at lighting fast speeds.
