Plugin updates causing errors in log
Wed Mar 07, 2018 7:46 am
Redrocker offline
Hi all,
Most times I can find answers to questions or issues that may arise by searching these forums. I have not been able to track down others with this latest one, and I apologize if it has been discussed/solved in another thread. As recently as the past week or so I have been getting lots of red in my Indigo log files. I never have been able to get the "broken pipe" issue fixed with the Alexa-Hue plugin, but I have a work around (restarting the plugin at the top of the hour) that seems to satisfy the problem for now.
The new problem is that when a plugin (any plugin) does an update check, or I manually initiate one myself, i get the entries in the log below:
 Ring Doorbell                   Checking for updates...
   Ring Doorbell Error             Error in plugin execution runConcurrentThread:
  File "plugin.py", line 153, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/MrSlim.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
   Ring Doorbell Error             plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
At first I though it may have been my new Fingbox blocking traffic somehow, but unplugging it does nothing to alleviate the problem.
Here is another instance with the Alexa-Hue plugin:
   Alexa-Hue Bridge Error          Error in plugin execution MenuAction:
  File "plugin.py", line 126, in checkForUpdates
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 88, in checkForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 175, in _prepareForUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 97, in getUpdate
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 117, in getLatestRelease
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/ghpu.py", line 145, in _GET
Anyone else experiencing this issue? Any suggestions on how to fix it (or the "broken pipe" issue)?
Thanks for looking,
~Mark
Indigo 2021.2
Wed Mar 07, 2018 8:17 am
Colorado4Wheeler offline
Re: Plugin updates causing errors in log
I believe that is related to the SSL depreciation on some sites, specifically Git. It's been discussed quite a bit over the last week or two. Here is one thread that talks about it and here is another one.
Wed Mar 07, 2018 8:26 am
Redrocker offline
Thanks for the reply Colorado4Wheeler. I guess I needed to dig just a little deeper this time.
~Mark
Indigo 2021.2
