closing socket
Wed Feb 14, 2018 5:34 pm
closing socket
I open a tcpip socket at startup of plugin and at the end it is closed()
issue:
when restarting plugin it takes about 15 seconds before the open works again, .
(12345 is the port# used)
open:
socketServer = ThreadedTCPServer((192.168.1.x,12345), ThreadedTCPRequestHandler)
testing after socketServer is done with
/usr/sbin/lsof -i tcp:12345
shows nothing open
as soon as /usr/sbin/lsof -i tcp:12345 shows a port (that takes 15 seconds)
TCPserverHandle = threading.Thread(target=socketServer.serve_forever)
TCPserverHandle.daemon =True # don't hang on exit
TCPserverHandle.start()
works fine.
closing is done like this at the end of plugin works w/o problem:
        if self.socketServer is not None:
            self.socketServer.shutdown()
            self.socketServer.server_close()
            indigo.server.log( u"stopped tcpip stack")
Also works when the plugin is disabled and then enabled, but when plugin gets restarted (by itself).. looks like there is still something open, but not visible and it takes OSX ~ 15 secs to finally close the socket.
==> is there anything that can be done to force a close ie give some parameters to elf.socketServer.shutdown()
tried
self.socketServer.shutdown(socket.SHUT_RDWR)
but that complains that 2 args are given, while one is expected ..
Wed Feb 14, 2018 7:24 pm
Colorado4Wheeler offline
Re: closing socket
It can be a little tricky. I use BaseHTTPServer myself and I had hang problems until I did multi-threading for the server itself and started it up the server in a different thread than the plugin as well.
def run (self, port, username = None, password = None):
      self.myThread = threading.Thread(target=self.startServer, args=[port])
      self.myThread.daemon = True
      self.myThread.start()
def startServer (self, port, username = None, password = None):
         port = int(port)
         # Multi Threaded
         self.httpd = ThreadedHTTPServer(('', port), AuthHandler)
         self.httpd.serve_forever()
      except Exception as e:
         self.logger.error (ext.getException(e))
class ThreadedHTTPServer(ThreadingMixIn, HTTPServer):
    """Handle requests in a separate thread."""
Wed Feb 14, 2018 8:55 pm
Re: closing socket
I believe I am doing the same ..
the only issue I have is that the socket is not release immediately after shutdown & close
and don't understand why
complains about 2 args instead of 1 expected..
Wed Feb 14, 2018 9:37 pm
Re: closing socket
Here is how I close:
   def stop (self):
      self.logger.debug ("Stopping HTTP server")
      self.httpd.shutdown
      #self.httpd.socket.close() # not really needed, causes Indigo headaches and not using it doesn't leave open sockets because the thread is destroyed
      self.httpd = None
      self.myThread.paused = True
      self.stopped = True
Wed Feb 14, 2018 10:55 pm
Re: closing socket
I believe
self.httpd.shutdown
should be
self.httpd.shutdown()
Thu Feb 15, 2018 8:17 am
Re: closing socket
kw123 wrote:
I believe
self.httpd.shutdown
should be
Probably, but it's been working so I'm leaving it :lol:
Thu Feb 15, 2018 8:33 am
Re: closing socket
Close()
Is the one that must be done.
Shutdown() sends to peer a message it’s over.
Close() will actually shut things down
Thu Feb 15, 2018 9:17 am
Re: closing socket
I'm not sure of the semantics of doing it with ThreadedTCPServer, but when you create the listening socket set the socket option SO_REUSEADDR. Example:
socket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
Thu Feb 15, 2018 10:15 am
Re: closing socket
Thanks will try that.
Thu Feb 15, 2018 10:21 am
Re: closing socket
Also, set the socket timeout to something lower - it could be that it's waiting for something and just hasn't timed out yet. The default is 30 seconds (way too long for most things IMO).
