trigger shows old state names
Tue Jan 16, 2018 1:59 pm
I have modified states in a device and would like to update a trigger
In the trigger I want to select a "device/state" has changed.
when opening the state sector in action I see old state keys only.. I have changed the state keys(removed GasScore added AirQuality)
"AirQuality" is missing in the trigger window devices/state listing, GasScore is still there
Restarting server, start/stop the device, edit/save the device does not change it .
selecting state="GasScore" (which is removed) the trigger in the trigger home window actually then shows the right device/state "AirQuality" after saving
I guess something needs to be refreshed on the server.
deleting the device and recreating would fix i? but then I loose all the links
Screen Shot 2018-01-16 at 13.53.19.png (5.87 KiB) Viewed 2930 times
Screen Shot 2018-01-16 at 13.29.26.png (183.45 KiB) Viewed 2930 times
Tue Jan 16, 2018 3:29 pm
Colorado4Wheeler offline
Re: trigger shows old state names
If you change the states on a device you need to refresh them, I do this on my deviceStartComm in my plugins to cover me for just that situation:
dev.stateListOrDisplayStateIdChanged()
This should resolve your issue if I understand it correctly.
Tue Jan 16, 2018 5:22 pm
Yes that is executed . It is still there.
Tue Jan 16, 2018 5:28 pm
I'd have expected just the dev.stateListOrDisplayStateIdChanged() call to refresh it. Are you positive it was called for the device in question? And a shutdown/restart of both the Indigo Server and Client didn't help?
Tue Jan 16, 2018 6:05 pm
this is the structure:
1. set flag to init at startup
2.in def deviceStartComm(): if init do the state update
3. in run runConcurrentThread set flag to run to avoid constantly updating the states.
and yes, the server was restarted
    def __init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs):
        indigo.PluginBase.__init__(self, pluginId, pluginDisplayName, pluginVersion, pluginPrefs)
        self.pluginState                = "init"
    def deviceStartComm(self, dev):
            if self.pluginState == "init":
                dev.stateListOrDisplayStateIdChanged()  # update  from device.xml info if changed
        self.pluginState    = "run"
Tue Jan 16, 2018 6:12 pm
Did you quit the client (after the server shutdown)?
Tue Jan 16, 2018 6:47 pm
no, but did that too NOW ... and still the same result .. see attached screen shots
Screen Shot 2018-01-16 at 18.47.14.png (42.75 KiB) Viewed 2855 times
Screen Shot 2018-01-16 at 18.46.24.png (58.07 KiB) Viewed 2855 times
Tue Jan 16, 2018 6:51 pm
Search your entire Devices.xml file for "GasScore". Is it anywhere in there? As the value for a <TriggerLabel> node?
Tue Jan 16, 2018 7:09 pm
                <State id="AirQuality">
                    <ValueType>number</ValueType>
                    <TriggerLabel>GasScore</TriggerLabel>
                    <ControlPageLabel>GasScore</ControlPageLabel>
                </State>
indigo is always right ..
:oops:
Tue Jan 16, 2018 8:36 pm
Lol, we’ve all done something similar :lol:
Wed Jan 17, 2018 6:52 am
My personal favorite is when I save a Python script with the name of an internal Python method.
Wed Jan 17, 2018 8:58 am
One of mine is, especially with so many plugins I've written (I've only published maybe 1/2) that I make a change and it doesn't show up even though I restarted the plugin a dozen times - only to realize I've been restarting the wrong plugin or I didn't actually SAVE the file in my Python editor :roll:
Wed Jan 17, 2018 11:23 am
Yeah, I just love the "how in the world is this possibly happening?" type of bugs. One advantage we have here is I can search the Indigo source code to help narrow down the scope of the problem. Even with that though I still sometimes end up chasing my tail. :roll:
Wed Jan 17, 2018 11:26 am
I have long term damage to my forehead from banging it on my desk when that happens. After a while I start to get really mad too and talk to myself, my wife will walk in and wonder who I was just cussing at (because I talk to the code and my computer like it was person when I'm like this) and when I don't look up and ignore her entirely she knows I'm coding :P
Wed Jan 17, 2018 11:46 am
Some bugs can truly make you question your sanity. :mrgreen:
