Should Optimize crash the Indigo Server
Wed Dec 13, 2017 12:51 pm
CliveS offline
Still having optimise problems but this is when a device cannot be found it just crashes and then removes loads of devices and hangs the Gen5 Stick
From the logs
 Z-Wave                          Optimizing - update succeeded: "166 - Living Room Christmas Tree"
   Z-Wave                          Optimizing - update succeeded: "167 - Dining Room Relay Power Switch"
   Z-Wave                          Optimizing - update queued for next awake message: "073 - Kitchen Fibaro Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "093 - Keyfob (FGKF601)"
   Z-Wave                          Optimizing - update queued for next awake message: "094 - .En Suite Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "099 - Living Room PST02 Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "101 - Hall Coat Cupboard Switch"
   Z-Wave                          Optimizing - update queued for next awake message: "113 - Kitchen PST02 Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "116 - .Bathroom Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "117 - .Conservatory Left Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "118 - .Conservatory Right Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "119 - .Conservatory Garden Door Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "120 - .Bedroom 1 Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "121 - 121 Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "122 - Bathroom Neo Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "125 - .Kitchen Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "126 - 126  Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "127 - .Utility Room Outside Door Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "135 - Bedroom 1 Jane WallMote"
   Z-Wave                          Optimizing - update queued for next awake message: "136 - 136  Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "137 - 137  Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "138 - 138  Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "140 - 140  Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "141 - 141  Door/Window Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "142 - .Conservatory Sliding Door Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "143 - Drive Garage Door Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "145 - Living Room Neo Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "146 - Drive Front Door Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "148 - Heiman 1 Notification Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "152 - Kitchen Neo Motion"
   Z-Wave                          Optimizing - update queued for next awake message: "155 - .Bathroom Door Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "163 - Motion Sensor"
   Z-Wave                          Optimizing - update queued for next awake message: "169 - Bathroom Fibaro Motion"
   Z-Wave Error                    Optimizing - update failed: "008 - Garage Far Power Switch"
   Z-Wave Error                    Optimizing - update failed: "028 - En Suite Floor Heating Thermostat"
   Z-Wave Error                    Optimizing - update failed: "124 - Relay Switch 1"
13 Dec 2017, 18:34:41
   Z-Wave                          Optimizing - started network optimization for nodes: 8
   Z-Wave                          Optimizing - starting "008 - Garage Far Power Switch"
13 Dec 2017, 18:34:56
   Z-Wave                          Optimizing - ping timeout
   Z-Wave                          Optimizing - finding neighbors
13 Dec 2017, 18:35:28
   Z-Wave Error                    send sendPingZwaveCommand failed after 9 attempts
   Z-Wave Error                    restarting serial connection in 5.0 seconds
   Interface Failure               lost connection with interface
13 Dec 2017, 18:36:18
   Z-Wave Error                    send getVersion failed after 9 attempts
13 Dec 2017, 18:36:55
   Z-Wave                          connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodemFA131 (firmware 1.00)
   Z-Wave Error                    module 028 included in controller no longer matches device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
   Z-Wave Error                    module 073 included in controller no longer matches device "Kitchen Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 64, 3), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 085 included in controller no longer matches device "Server Room Repeater Controller Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 093 included in controller no longer matches device "Keyfob (FGKF601)" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
   Z-Wave Error                    module 094 included in controller no longer matches device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 099 included in controller no longer matches device "Living Room PST02 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 24, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 103 included in controller no longer matches device "En Suite Floor Heating Switch" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 118 included in controller no longer matches device ".Conservatory Right Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 120 included in controller no longer matches device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
   Z-Wave Error                    module 124 included in controller no longer matches device "124 - Relay Switch 1" type (controller module type: zwRelayType/zwRelayType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 125 included in controller no longer matches device ".Kitchen Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 86, 104), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 135 included in controller no longer matches device "Bedroom 1 Jane WallMote" type (controller module type: zwCustomType/zwCustomType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
   Z-Wave Error                    module 139 included in controller no longer matches device "Motorhome Neo Charger Socket" type (controller module type: zwCustomType/zwCustomType (4, 24, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 143 included in controller no longer matches device "Drive Garage Door Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 150 included in controller no longer matches device "Bedroom 1 Ceiling Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
   Z-Wave Error                    module 151 included in controller no longer matches device "Bathroom Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
   Z-Wave Error                    module 153 included in controller no longer matches device "Neo Relay Power Plug - MacBook Air" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 155 included in controller no longer matches device ".Bathroom Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 156 included in controller no longer matches device "Living Room Aeon 4 Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 157 included in controller no longer matches device "Kitchen Spot Lights" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
   Z-Wave Error                    module 158 included in controller no longer matches device "Kitchen Undercupboard Lights" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
   Z-Wave Error                    module 159 included in controller no longer matches device "Garden Lights" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 160 included in controller no longer matches device "Hall Repeater Relay Power Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 163 included in controller no longer matches device "163 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 164 included in controller no longer matches device "Siren" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 5))
   Z-Wave Error                    module 167 included in controller no longer matches device "Dining Room Relay Power Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 168 - Siren
   Z-Wave Error                    module 169 included in controller no longer matches device "Bathroom Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
   Z-Wave                          Optimizing - requesting neighbor list update
   Z-Wave                          Optimizing - stopped
   Z-Wave                          neighbor list update complete (no change)
   Z-Wave                          Optimizing - finished "008 - Garage Far Power Switch"
   Z-Wave                          Optimizing - complete
   Z-Wave                          Optimizing - update succeeded: "008 - Garage Far Power Switch"
13 Dec 2017, 18:38:46
CliveS
Wed Dec 13, 2017 7:40 pm
Re: Should Optimize crash the Indigo Server
I have inadvertently come precariously close to authoring a Crash the Indigo Server plugin from time to time, but other than that nothing 'should' crash the Indigo server.
That said, I have never had the Indigo server crash as a result of network optimization. If it were me, I would try rerunning the Indigo Installer to see if that fixes the problem you're seeing.
Thu Dec 14, 2017 1:42 am
CliveS offline
I did download and reinstall Indigo but had 3 more incidents overnight. Common factor was all the errors are related to the garage which is 20 feet from the nearest house device. These have worked fine for months but now the temperature is around zero centigrade I am suspecting that the garage devices now have a reduced range and so I have removed them from the system.
I still cannot understand why this causes the removal of all the other devices, is it a bad gen5 stick?
CliveS
Thu Dec 14, 2017 4:21 pm
I'd argue that this isn't a crash of the Indigo Server. A crash would mean the server immediately quits (and a crash report file is logged).
This looks like a hang of the Z-Wave controller (Z-Stick), that then causes Indigo to try to recover by restarting its communication (initialization handshake) over. That then fails because the Z-Stick is still out-to-lunch. The Z-Stick reports bogus module information to Indigo at this point, so Indigo decides something is very wrong and disables communication for the modules that are now reported with bad information (all of them?).
I'm not sure what is causing this behavior. It could be a module (like the garage ones), or it could be the Z-Stick is in a bad state. Resetting the Z-Stick (via the Interfaces->Z-Wave menu) might help, but that can be a painful process since you have to re-include all of your modules. I'd start though probably by removing (excluding) just the suspect modules, then re-including those to see if that helps the situation.
Sun Dec 17, 2017 4:36 am
Colly offline
CliveS,
I've had similar issues - check out http://forums.indigodomo.com/viewtopic.php?f=131&t=19826. At the moment I'm just living with it and over the Xmas break I might get around to digging a bit more into it and exclude/re-include all the affected devices. The most problematic device I have is a Fibaro Universal sensor so I've set up a schedule to run regularly to re-enable if it's disabled. I'll also do a double check whenever I'm syncing a new device or a re-sync - for me its not consistent, sometimes I'll have 5,6, 7 devices disabled and other times just the Fibaro. I'm leaning on Matt's side that it may be a dodging stick but not 100% convinced :|
Sun Dec 17, 2017 6:28 am
CliveS offline
I think I have narrowed it down to distance as when I try to optimise the garage switches (3 of them) they do not see each other sometimes and other times only see 1 or 2 but never all 3 see each other (and sometimes they just screw up completely!!!).
Bring them in the house and they are see everything around them no problem.
The trouble is that when they do "fail" it screws the Gen5 stick and not even rebooting the Mac Mini from cold will reset it, only by removing it from the USB port and plugging it back in works so I can't test for and then re-enable as the z-wave is not enabled!
Why it randomly kills some but not all devices is most probably down to the stick killing the devices and when it locks it can't finish them all off.
The strange thing is only an Aeotec multi-sensor 4 in the living room running on USB power can see 1 of the garage switches, all the mains powered devices in the living room (4) can't see any.
Before I get a new Gen5 stick I will try putting z-wave powered switches on extension leads just outside the front door and the garage door and see if that will extend the range.
CliveS
Sun Dec 17, 2017 6:55 am
Do you have any sense how many hops the commands must travel to get to the devices when they're placed in their permanent locations? There is a hop limit with Z-Wave.
Another thing to try -- which may or may not be a lot of work depending on the number of devices you have -- is to resync all your devices starting with the one closest to the Z-Stick and working your way out. Do battery-powered devices last. This might improve your situation by minimizing the number of hops to get to any one device.
Sun Dec 17, 2017 12:05 pm
CliveS offline
Not sure how to tell what is connected direct to the Z-stick and which go via a hop but I have now optimized the powered devices nearest the stick as you suggested, (does optimise and resync do the same for looking for neighbours?) and with a Fibaro dimmer module temporarily placed outside the garage door I have a much improved network in the garage, just need to wire it inside a wall light on the garage which is always live (has a Philips Hue bulb) and I should be sorted.
CliveS
