SMTP connection does not close connection
Tue Dec 05, 2017 3:34 pm
I guess this for M&J
in my "/usr/sbin/lsof -i tcp" i have 100++ of these
IndigoSer 60611 karlwachs   30u  IPv4 0xad7f4c2af4a0e897      0t0  TCP 192.168.1.50:53243->40.97.119.178:smtp (CLOSED)
IndigoSer 60611 karlwachs   40u  IPv4 0xad7f4c2ad0c33a87      0t0  TCP 192.168.1.50:58296->40.97.119.178:smtp (CLOSED)
IndigoSer 60611 karlwachs   46u  IPv4 0xad7f4c2adc861a87      0t0  TCP 192.168.1.50:59228->40.97.119.178:smtp (CLOSED)
IndigoSer 60611 karlwachs   53u  IPv4 0xad7f4c2ad0c3437f      0t0  TCP 192.168.1.50:49266->40.97.119.178:smtp (CLOSED)
IndigoSer 60611 karlwachs  189u  IPv4 0xad7f4c2af49fc56f      0t0  TCP 192.168.1.50:59622->40.97.119.178:smtp (CLOSED)
I
I have an issue with mail, password rejected although it is correct (have to do an online web session to reenable). When this is the case I get the hanging closed connections
not a serious issue, but something does not close its socket . Adding 1 every 10 minutes
Tue Dec 05, 2017 5:43 pm
Re: SMTP connection does not close connection
So it sounds like the hanging connections only occur when there is the authentication failure?
Have you tried using the BetterEmail plugin instead of Indigo's built-in SMTP client? Indigo's built-in SMTP and POP clients are from a legacy library we are using, but eventually we will be transitioning to using python like the BetterEmail plugin.
