Z-Wave Slow?
Fri Oct 20, 2017 10:35 am
Frakke offline
Z-Wave Slow?
I've got this setup, when clicking once at the fibaro button, the lights go on.
But this doesn't work all the time.
Got these in the log:
Z-Wave Debug                    RCVD nonceFetch: node 028
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 90 AD AD C2 61 D2 41 31 25 F9 BE
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 90 AD AD C2 61 D2 41 31 25 FA BD
   Z-Wave Debug                    . .  nonceReport: requeuing 1 unsolicited packets
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 90 AD AD C2 61 D2 41 31 25 FB BC
   Z-Wave Debug                    RCVD nonceReport: 18 (RETRANSMIT REQUEST)
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 90 AD AD C2 61 D2 41 31 25 FB BC (re-sent because retransmit request)
20 Oct 2017 at 18:33:58
   Z-Wave Error                    no ack/nak/busy reply (028) for nonceReport (re-sending)
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 FB 01 03 9E 8C (node NAK)
   Z-Wave Debug                    . .  nonceReport: requeuing 13 unsolicited packets
   Z-Wave Debug                    RCVD encryptedPacket: C4 BB ED E0 9F C7 (decrypted)
   Z-Wave Error                    RCVD encryptedPacket: unexpected sequence byte C4
   Z-Wave Error                    RCVD encryptedPacket:  full raw packet 01 1F 00 04 10 1C 19 98 81 0A 5F DF 4E 13 B3 5F F2 FC 34 7E 9D 5B E7 90 17 C0 43 71 76 14 58 36 CF
   Z-Wave Error                    RCVD encryptedPacket: encrypted packet FC 34 7E 9D 5B E7
   Z-Wave Error                    RCVD encryptedPacket: decrypted packet C4 BB ED E0 9F C7
   Z-Wave Error                    encrypted command received from node ID 028 has invalid CBC-MAC value (ignoring)
   Z-Wave Debug                    reusing outgoing nonce 1E 8D 2C 78 11 8E 00 BC
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 1E 8D 2C 78 11 8E 00 BC 25 FC CE
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 FC 01 03 8C 99 (node NAK)
   Z-Wave Debug                    timeout waiting for module command after sending nonce report (not critical)
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 1E 8D 2C 78 11 8E 00 BC 25 FD CF
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 FD 01 03 91 85 (node NAK)
   Z-Wave Debug                    SENT nonceReport: 01 11 00 13 1C 0A 98 80 1E 8D 2C 78 11 8E 00 BC 25 FE CC
   Z-Wave Debug                    RCVD nonceReport: 01 07 00 13 FE 01 03 89 9E (node NAK)
What can I do more?
regards
Sat Oct 21, 2017 3:09 pm
Re: Z-Wave Slow?
I would recommend excluding the module and re-including it with encryption disabled. Unless you absolutely need encryption for a module (door/window sensors, locks, and garage door controllers), we recommend against using it. It just isn't as reliable and requires significantly more commands. This increases the likelihood of congestion/collisions, is less responsive, and will chew through batteries more quickly. Also we've noticed the quality/robustness across manufactures and models of encryption varies. The locks manufacturers have it down pretty well, but some of the newer module seem to have issues.
Wed Nov 08, 2017 10:21 am
7rdr7 offline
Re: Z-Wave Slow?
Matt,
Encryption is recommended for Door Locks and Garage Door controllers, correct?
Thanks.
Wed Nov 08, 2017 10:53 am
Re: Z-Wave Slow?
Yes, recommended for both of those and required by almost/all locks to work correctly.
