Re: Feature request
Posted: Sun Oct 01, 2017 5:15 pm
lanbrown wrote:I'm already going to solve the lack of built-in encryption (at least by not use Prism) via the web portion through a different way.
The reflector is secure - it uses SSL to our hosted reflector server and a secure ssh tunnel from there to your Indigo Server Mac - so the entire process is secured.
lanbrown wrote:I have no idea how many people use a dedicated system but it appears quite a few do. With macOS Server being nothing more than an add-on for the past few releases, any plans on making Indigo more integrated? [SNIP]If macOS server was used, you could add a cert to the web server and then also have username and password authentication either via Open Directory (OD) or Microsoft AD. If you could even support groups then you could assign certain people only to have access to certain devices as well. I'm sure this would be large rewrite to Indigo though.
All of the things you mention can be done without macOS Server - just an FYI (you have to have a pretty decent understanding of how unix/macOS works to get it all configured).
We've had requests for multiple users (and groups) over the years, and it's on our feature request list. The priority is pretty low however.
