can not connect to indigos server
Tue Jul 25, 2017 4:23 pm
about every 6 hours or so I can not connect to the indigo server
I get this:
Error failed to create reflector connection: local server unreachable
Error check your Firewall and Network configurations and try restarting the server
Error reflector reconnection scheduled in 15 minutes
then I can not connect on the LOCAL network via wifi or ethernet to the indigo server..(touch or client)
An existing connection stays open, Even when I disconnect the indigo client and reconnect, but not on a new one (e.g. my laptop or iPhone) which where not connected before.
There is nothing in the system log file from indigo
After I restart the indigo server everything goes back to normal
anywhere I should look?
Tue Jul 25, 2017 6:51 pm
Re: can not connect to indigos server
That is really bizarre. I'm not sure what is going on. Regarding this:
So you can close the open (and working) Indigo client connection from another local Mac, and then that Mac can again reconnect successfully? But if you try to connect from a different Mac (or use Safari to connect to the Web server) it fails?
Tue Jul 25, 2017 7:14 pm
yes..
but its running now... what should I look for when it happens again ?
Tue Jul 25, 2017 7:28 pm
Karl - this may seem a little strange, but I was having some really odd behavior in the neighborhood of yours. I had some strange failures (mine were different than yours*) and was unable to connect with Indigo remotely. I was unable to connect even after restarting the Indigo server. Only a full reboot would solve the problem. It seems that I was able to trace the issue to a parasitic USB hub (the Z-Stick was NOT plugged into the hub). While I can't guarantee it was the hub; since pulling the hub, no errors.
* I was sometimes getting fatal memory errors that caused Indigo to shut down or causing no acks. In the instance of no acks--where the server was still running--I was unable to access it via an Indigo client, from Indigo Touch, or through Indigo Web.
Tue Jul 25, 2017 7:30 pm
From the Indigo Server Mac can you connect to the Indigo Web Server (say, via the Indigo Go->Browser Devices Page menu item)?
Can you connect to other services on that Mac when it is in the bad state (like file server)?
Tue Jul 25, 2017 8:16 pm
Well right now it works fine. But yes I could do screen sharing, ssh , ftp
Tue Jul 25, 2017 9:49 pm
Dave. Yes on my old Mac Pro I have sometimes issues with USB. But only when I pull a cable out and put it back in.
If I don't touch all is fine.
