PlugIn Instantiation Question
Wed Jul 19, 2017 7:13 am
HFTobeason offline
When I launch Indigo Server on my primary machine, I see the usual stream of log messages - including the following section:
WebServer                        started on port 8176 -- digest authentication enabled
Started plugin "SQL Logger 2.0.5"
SQL Logger                      connected to /Users/hft/Documents/Indigo/indigo_history.sqlite
SQL Logger                      searching for unused device and variable tables
Started plugin "Action Collection 2.0.4"
Started interface "INSTEON Commands 2.0.10"
Started plugin "NOAA Weather Plus 1.1.19"
Started plugin "TED - The Energy Detective 2.0.0"
SQL Logger                      search complete (none found)
SQL Logger                      updating all device tables
TED - The Energy Detective      Your plugin version, v2.0.0, is current.
TED - The Energy Detective      Polling Interval: 5
SQL Logger                      updating all variable tables
Note that this section appears to be repeated once.
However, if I open a remote Indigo session on another machine and look at the exact same section of the log, I see this:
Note that I'm only seeing one set of these entries in the remote log.
Ideas? Is this an issue?
Thanks.
Wed Jul 19, 2017 9:17 am
Re: PlugIn Instantiation Question
I don't believe it's an issue, though I'm not sure what's going on. You can look at the actual log file (which is formatted slightly differently) and see if the messages are actually repeated in there. It's in:
/Library/Application Support/Perceptive Automation/Indigo 7/Logs/
Wed Jul 19, 2017 10:32 am
Because of some timing issues the Indigo client window can show some duplicate log messages when it first starts up. It is purely an Indigo client / UI glitch though – the log file itself should have the entries only once.
Wed Jul 19, 2017 10:36 am
HFTobeason offline
Curious... The raw log file shows only the single iteration of the line items - but every time I restart the main machine (hosting Indigo Server), I get the duplicate entries. BTW, I started examining this because my TED 5000 plugin started locking up on me a few weeks ago (viewtopic.php?f=143&t=18670).
Wed Jul 19, 2017 10:37 am
HFTobeason offline
Whoops - overlapped posts!
Wed Jul 19, 2017 10:38 am
HFTobeason offline
And, as always, thank you for the rapid replies!
