Connection from Client to indigo server remotly
Tue Jun 20, 2017 6:00 pm
Radjin offline
I installed the client on my laptop, can connect via SSH and Back to My Mac, I forwarded the two ports, 1176 and 8176 to my server however I cannot connect with the indigo client.
Am I missing a step?
It's not rocket science...
Tue Jun 20, 2017 6:32 pm
johnfdl offline
Re: Connection from Client to indigo server remotly
Just to be sure we eliminate the obvious.....
  1. You've started Indigo first on the server?
  2. You haven't changed the default ports?
  3. You don't have a firewall blocking the traffic?
  4. From the client, you are entering the external IP address of your router?
  5. Does it work if you connect when the client and server are on the same local network?
Wed Jun 21, 2017 6:46 am
Radjin offline
  1. You've started Indigo first on the server? Yes
  2. You haven't changed the default ports? Correct
  3. You don't have a firewall blocking the traffic? Correct
  4. From the client, you are entering the external IP address of your router? Host name (xxx.com)
  5. Does it work if you connect when the client and server are on the same local network? Yes
Wed Jun 21, 2017 7:09 am
Different Computers offline
For the server address, are you using the external IP address or some dynamic DNS address? The prism reflector address does NOT work for the client to the server. This bit me in the ass 6 months or so ago.
Wed Jun 21, 2017 3:20 pm
Radjin offline
I run a small web server and can access the website perfectly. So using that addresss to get to my server the client at my remote location tells me 'cannot connect to the indigo server, check my internet connection'. I don't use the prism reflector
Wed Jun 21, 2017 3:38 pm
The Mac GUI Indigo client connects to port 1176 (by default), which is the native Indigo Server (which is not HTTP based).. Indigo Touch and Web browsers use the Indigo HTTP Web Server which is on port 8176 by default.
They are both just normal TCP sockets, so setting up TCP forwarding for those sockets is all you have to do. If it isn't working, then the problem is either the port forwarding isn't set up correctly or the Mac's firewall is blocking incoming connection.
Wed Jun 21, 2017 3:40 pm
kwijibo007 offline
Radjin wrote:
[*]From the client, you are entering the external IP address of your router? Host name (xxx.com)
For the sake of troubleshooting, have you tried entering the IP address directly? Maybe some strange DNS issue is causing the issue?
Wed Jun 21, 2017 5:31 pm
Radjin offline
Of all things it turned out to be the VPN I use when traveling. Why it would be a problem I am not sure as all other services work perfectly.
Thanks everyone for the help.
Wed Jun 21, 2017 5:42 pm
johnfdl offline
And here I thought it was the 'xxx.com' hostname you were putting in. Some spicy material on that hostname.. :twisted:
Wed Jun 21, 2017 6:47 pm
Radjin offline
Next time I will use 555.com
Thu Jun 22, 2017 6:39 am
johnfdl offline
Much more refined content on 555.com
Thu Jun 22, 2017 6:50 am
I'm reminded of a story where (I think it was) Microsoft wrote a Win NT setup manual that used "http://example.com" throughout, and the copy editors never once checked to see what was at example.com or who owned it.
example.com ended up getting a lot of weird traffic.
