Anyone seeing anything similar to this?
When remotely connecting to the Indigo server the Indigo client will often fail on the first connection. When it fails I quit the client and open it again, which then opens straight away. Furthermore, when it does connect and I check the logs I always see errors have occurred during the failed remote connection attempt.
There is a pattern and is reproducible.
1. The first connection will fail. The Server Connection Status window is displayed for about 10-15 seconds and then disappears but without the Indigo UI opening. The second attempt right after I quit it connects straight away.
Occasionally, after the 10-15 second display The Server Connection Status widow the Indigo UI does open, but that is also after a further delay.
2. The failure is only after a connection attempt to the Indigo server has not occurred for around 20mins or so. And the errors are only when using the Mac clients. (Tested using 2 Macs). No such errors occur when using the iOS clients.
3. It's always the same kind of errors. See below.
4. This started around the time I installed Indigo 7.0.3 and macOS 10.12.3 - whether it's Indigo, macOS, or both, I don't know.
They are all on the same network. And as you can see from some of the log grabs that I was able to authenticate straight after the failed attempt, while others after the long pause. One of the IP connections is from Uptime Robot, which I use to ping the Indigo server IP address and port to check for uptime status, so that can be ignored.
And just to be clear, I never see errors with with any of the plugins other than during the connection attempt.
Here are the errors:
- Code: Select all
2017-03-28 22:48:06.686 Application Indigo Cocoa client authenticated (192.168.0.12)
2017-03-28 22:48:25.875 Application Indigo Cocoa client disconnected (192.168.0.12)
2017-03-28 22:48:28.809 Application Indigo Cocoa client authenticated (192.168.0.12)
2017-03-28 22:48:30.392 EPS - Device Extensions Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 589, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Device Extensions.indigoPlugin/Contents/Server Plugin/eps/SmartIrrigation.py", line 300, in irrigationTimerTick
StandardError: ServerCommunicationError -- timeout waiting for response
2017-03-28 22:48:30.393 EPS - Device Extensions Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-03-28 22:48:30.393 Airfoil Pro Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 533, in runConcurrentThread
2017-03-28 22:48:30.394 Airfoil Pro Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-03-28 22:48:30.395 DSC Alarm Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1526, in runConcurrentThread
2017-03-28 22:48:30.396 DSC Alarm Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-03-28 22:48:30.398 Autolog Stella-Z Error Error detected in Autolog Plugin runConcurrentThread Method 'B'
2017-03-28 22:48:30.399 Autolog Stella-Z Error Error message: 'ServerCommunicationError -- timeout waiting for response'
2017-03-30 19:21:18.530 Application Indigo Cocoa client authenticated (192.168.0.11)
2017-03-30 19:21:42.981 EPS - Device Extensions Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 587, in runConcurrentThread
File "plugin.py", line 504, in resetHighLow
2017-03-30 19:21:42.983 EPS - Device Extensions Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2017-03-30 19:21:42.984 Airfoil Pro Error Error in plugin execution runConcurrentThread:
2017-03-30 19:21:42.985 Airfoil Pro Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
8 Apr 2017, 5:34:11 pm
8 Apr 2017, 6:07:11 pm
Z-Wave received "Porch Luminance" sensor update to 195 lux
Z-Wave received "Porch Humidity" sensor update to 22%
Z-Wave received "Porch Temperature" sensor update to 22.5 °C
Trigger Alarm_Living Room Motion Sensor
8 Apr 2017, 6:07:44 pm
Indigo Cocoa client disconnected (192.168.0.11)
8 Apr 2017, 6:59:38 pm
Trigger Monitor Conservatory Stella Z
Trigger Temp Conservatory Stella Z
8 Apr 2017, 7:00:08 pm
8 Apr 2017, 7:38:54 pm
Z-Wave received "Porch Luminance" sensor update to 24 lux
Z-Wave received "Porch Humidity" sensor update to 23%
Z-Wave received "Porch Temperature" sensor update to 21.6 °C
8 Apr 2017, 7:39:20 pm
Client disconnected (69.162.124.229)
fingscan in Line '5979' has error='expected a character buffer object'
fingscan -2 can not update variable ipDevsLastUpdate
restarting fingscan
exception code: ServerCommunicationError -- timeout waiting for response
WUnderground Error Problem parsing Weather data. Error: 2693 (Line (ServerCommunicationError -- timeout waiting for response)
Reloading plugin "fingscan 7.22.2"
Stopping plugin "fingscan 7.22.2" (pid 65966)
Stopped plugin "fingscan 7.22.2"
Starting plugin "fingscan 7.22.2" (pid 15097)
Started plugin "fingscan 7.22.2"
8 Apr 2017, 7:40:08 pm
