Help Indigo 7- Indigo Server is currently not responding
Sat Apr 01, 2017 6:29 am
dlbeck offline
I've been running Indigo on a Mac mini for several years without problems. Currently I run OS 10.12.3 on m y Mac. I upgraded to Indigo 7 and now get error messages often that say the Indigo Server is currently not responding. The pop up window appears with the Start Local Server button and I click on that and all my settings appear correct. Usually it doesn't allow me to restart the server and clicking start server does nothing. I am not that techy so lot of this stuff is over my head but currently running dozens of Insteon devices in my house.
Please help...my lighting doesn't work in the house without Indigo running. Can I go back to Indigo 6? What should I check?
Sat Apr 01, 2017 9:50 am
Re: Help Indigo 7- Indigo Server is currently not responding
Sounds like you might have added Indigo 6 or Indigo 7 as a startup item for the account that runs Indigo at some point, perhaps?
If so, delete those startup items and then try to restart Indigo 7. When the configuration screen comes up, select the option to have Indigo start every time the computer boots (I don't recall the exact wording of that setting, sorry.)
Sat Apr 01, 2017 11:50 am
dlbeck offline
Thanks Dave. I uninstalled Indigo 6 so that shouldn't be the problem but will double check.
Sat Apr 01, 2017 1:45 pm
You might also want to rerun the Indigo 7 installer just in case there is some odd permission issue - the installer should correct those.
Sun Apr 02, 2017 9:34 am
dlbeck offline
Thanks Jay. I re-ran the package installer and that did not help. In my Start Local Server menu I clicked on the link that states what account my reflector is assigned to and it says "The reflector connection is currently down." I checked my indigo account and it says I have an active reflector account. So not sure if that's the problem. But it's still not working. Any other ideas?
Sun Apr 02, 2017 9:52 am
dlbeck offline
I tried to open the Indigo Server via the terminal and got this:
Last login: Sun Apr 2 10:49:55 on ttys000
Davids-mini:~ MusicServer$ /Applications/Indigo\ 7.app/Contents/MacOS/Indigo\ 7 ; exit;
2017-04-02 10:51:20.829 Indigo 7[7545:218896] unable to modify user startup items preference
Thoughts?
Sun Apr 02, 2017 12:02 pm
Are you sure that the account you have Indigo installed under is an admin account? And are you running it from that account? It sure sounds like there's some kind of permission error.
