Preferably it would be good the have the possibility to have a choice to optimize battery and main powered devices separately.
The other issue is that after almost 6 hours non of the battery devices started the optimization !? See the log:
- Code: Select all
Z-Wave Optimizing - stopped
Z-Wave Optimizing - update succeeded: "007 - SR-Roleta Gabinet"
Z-Wave Optimizing - update succeeded: "011 - SL-Lampa przy drzwiach"
Z-Wave Optimizing - update succeeded: "013 - DL-Kinkiety przy WC"
Z-Wave Optimizing - update succeeded: "014 - DL-Plafon nad drzwiami w hallu"
Z-Wave Optimizing - update succeeded: "015 - DL-Gorne przy kuchni"
Z-Wave Optimizing - update succeeded: "018 - DL-Gorne salonu"
Z-Wave Optimizing - update succeeded: "019 - DL-Kinkiety salon"
Z-Wave Optimizing - update succeeded: "020 - SL-Gorne w kuchni"
Z-Wave Optimizing - update succeeded: "021 - DL-Lampa stojaca"
Z-Wave Optimizing - update succeeded: "022 - SL-Halogeny nad blatem"
Z-Wave Optimizing - update succeeded: "023 - SK-Kamera kuchnia"
Z-Wave Optimizing - update succeeded: "024 - SL-Kinkiet taras"
Z-Wave Optimizing - update succeeded: "026 - SR-Roleta srodek kuchnia"
Z-Wave Optimizing - update succeeded: "027 - SR-Roleta prawa kuchnia"
Z-Wave Optimizing - update succeeded: "032 - SI-Zamek furtki"
Z-Wave Optimizing - update succeeded: "034 - DL-Kinkiet front domu"
Z-Wave Optimizing - update succeeded: "036 - SI-RTV Salon"
Z-Wave Optimizing - update succeeded: "038 - SI-RTV Gabinet"
Z-Wave Optimizing - update succeeded: "040 - DL-Plafon schody dol"
Z-Wave Optimizing - update succeeded: "041 - DL-Plafon piwnica"
Z-Wave Optimizing - update succeeded: "042 - DL-Plafony boczne garaz"
Z-Wave Optimizing - update succeeded: "044 - SI-Zraszacz taras"
Z-Wave Optimizing - update succeeded: "045 - SL-Halogeny pod szafkami"
Z-Wave Optimizing - update succeeded: "046 - SI-Pralka"
Z-Wave Optimizing - update succeeded: "054 - SL-Lampy ogrodowe z tylu"
Z-Wave Optimizing - update succeeded: "055 - SI-Zraszacz przod"
Z-Wave Optimizing - update succeeded: "056 - CR-Czujnik bramy garazu"
Z-Wave Optimizing - update succeeded: "058 - SI-Otwieranie bramy garazu"
Z-Wave Optimizing - update succeeded: "060 - SR-Markiza gora"
Z-Wave Optimizing - update succeeded: "062 - DL-Kinkiet schody gora"
Z-Wave Optimizing - update succeeded: "083 - DL-Kinkiet obok grzegorza"
Z-Wave Optimizing - update queued for next awake message: "106 - CI-Przelacznik scen salon"
Z-Wave Optimizing - update queued for next awake message: "108 - TD-Termostat WC prawy"
Z-Wave Optimizing - update queued for next awake message: "109 - TD-Termostat Hall"
Z-Wave Optimizing - update queued for next awake message: "110 - TD-Termostat WC lewy"
Z-Wave Optimizing - update queued for next awake message: "113 - TD-Termostat Kuchnia"
Z-Wave Optimizing - update queued for next awake message: "120 - TD-Termostat Lazienka"
Z-Wave Optimizing - update queued for next awake message: "121 - TD-Termostat Sypialnia"
Z-Wave Optimizing - update queued for next awake message: "125 - TD-Termostat Pralnia"
Z-Wave Optimizing - update queued for next awake message: "126 - CR-Okno Gabinet"
Z-Wave Optimizing - update queued for next awake message: "128 - CR-Okno sypialnia"
Z-Wave Optimizing - update queued for next awake message: "129 - CR-Okno lazienka"
Z-Wave Optimizing - update queued for next awake message: "130 - CR-Szafa na pietrze"
Z-Wave Optimizing - update queued for next awake message: "132 - CR-Okno WC"
Z-Wave Optimizing - update queued for next awake message: "133 - CR-Okno Kuchnia"
Z-Wave Optimizing - update queued for next awake message: "134 - CR-Drzwi na taras"
Z-Wave Optimizing - update queued for next awake message: "148 - TD-Termostat Grzegorza Lewy"
Z-Wave Optimizing - update queued for next awake message: "149 - TD-Termostat Grzegorza Prawy"
Z-Wave Optimizing - update queued for next awake message: "155 - CT-Temperatura sypialnia"
Z-Wave Optimizing - update queued for next awake message: "157 - CR-Okno Grzegorza"
Z-Wave Optimizing - update queued for next awake message: "158 - CR-Okno Goscinny"
Z-Wave Optimizing - update queued for next awake message: "159 - CR-Okno pralnia"
Z-Wave Optimizing - update queued for next awake message: "160 - CR-Oko"
Z-Wave Optimizing - update queued for next awake message: "162 - CR-Wolny podloga lazienka"
Z-Wave Optimizing - update queued for next awake message: "163 - CR-Dachowe Gabinet"
Z-Wave Optimizing - update queued for next awake message: "177 - CR-Drzwi do ogrodu"
Z-Wave Optimizing - update queued for next awake message: "178 - TD-Termostat Goscinny"
Z-Wave Optimizing - update queued for next awake message: "182 - CZ-Czujnik zalania piwnica"
Z-Wave Optimizing - update queued for next awake message: "183 - TD-Termostat Schody"
Z-Wave Optimizing - update queued for next awake message: "188 - CG - Licznik Gazu"
Z-Wave Optimizing - update queued for next awake message: "192 - TD-Termostat Gabinet"
Z-Wave Error Optimizing - update failed: "025 - SR-Roleta lewa kuchnia"
Z-Wave Error Optimizing - update failed: "047 - SI-Piec CO"
Z-Wave Error Optimizing - update failed: "063 - DL-Gorne schody"
There is also some issue with Danfoss Thermostats as in general after they are awake the optimization failes:
- Code: Select all
Z-Wave received "TD-Termostat Gabinet" heat setpoint is 22.00 °C
Z-Wave Optimizing - starting for awake device "192 - TD-Termostat Gabinet"
Z-Wave requesting neighbor list update
20 Jan 2017, 16:15:48
Z-Wave neighbor list update failed
Z-Wave Error Optimizing - update failed: "192 - TD-Termostat Gabinet"
20 Jan 2017, 16:16:05
Z-Wave received "TD-Termostat Hall" heat setpoint is 21.00 °C
Z-Wave Optimizing - starting for awake device "177 - CR-Drzwi do ogrodu"
WebServer Indigo Touch client connected from 192.168.0.111
Z-Wave received "TD-Termostat Grzegorza Prawy" heat setpoint is 21.00 °C
Z-Wave neighbor list updated from 7, 11, 12, 13, 14, 15, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 32, 34, 36, 38, 42, 44, 45, 46, 54, 55, 58, 60, 63, 84, 86, 88, 90, 101, 102, 164, 168, 169, 170, 172, 174, 176, 180, 181, 185, 186 to 7, 11, 13, 14, 15, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 32, 34, 36, 38, 40, 42, 44, 46, 54, 55, 58, 60, 62, 63, 83, 84, 85, 86, 88, 90, 100, 101, 102, 164, 168, 169, 170, 172, 174, 175, 176, 180, 181, 185, 186, 200
Z-Wave Optimizing - update succeeded: "177 - CR-Drzwi do ogrodu"
Z-Wave received "TD-Termostat WC lewy" heat setpoint is 22.00 °C
Z-Wave Optimizing - starting for awake device "110 - TD-Termostat WC lewy"
20 Jan 2017, 16:17:13
Z-Wave Error Optimizing - update failed: "110 - TD-Termostat WC lewy"
20 Jan 2017, 16:17:52
Z-Wave received "TD-Termostat Goscinny" heat setpoint is 19.00 °C
Z-Wave Optimizing - starting for awake device "178 - TD-Termostat Goscinny"
20 Jan 2017, 16:18:30
Z-Wave Error Optimizing - update failed: "178 - TD-Termostat Goscinny"
Z-Wave received "TD-Termostat Sypialnia" heat setpoint is 19.00 °C
Z-Wave Optimizing - starting for awake device "121 - TD-Termostat Sypialnia"
20 Jan 2017, 16:19:24
Z-Wave Error Optimizing - update failed: "121 - TD-Termostat Sypialnia"
Z-Wave received "TD-Termostat Kuchnia" heat setpoint is 26.00 °C
Z-Wave Optimizing - starting for awake device "113 - TD-Termostat Kuchnia"
My suggestion is to improve that procedure as it's very important for network stability especially after you remove or change any device.
