Since a couple of days my Indigo server hangs at night and today just an hour ago..
See images below.
Any idea how to troubleshoot this?
thanks!
regards
jay (support) wrote:That's almost always a result of one of these:
- A runaway embedded AppleScript stalls the server so it can't communicate with the client.
- A plugin is having some kind of difficulty and is causing a lot communication with the server, which slows down any communication with the client.
- Something else on your system is eating up CPU cycles causing everything to slow down. Some networking issues will cause lots of long (30s) network timeouts that may slow things down.
When you get that dialog, one thing to do is to open up Activity Monitor and see if there's anything eating up lots of CPU. For instance, if you have the Developer menu enabled in Safari and you have caches disabled, you'll often get a runaway process called nsurlstoraged (or similar) and that will eat well over 100% cpu. This is a known bug in Safari on Yosemite and above I believe.
Point being that anything eating up lots of CPU will cause the client to timeout when trying to talk to the server.
Frakke wrote:Also, nothing is working any more at this moment. So, no connection to server from anywhere, client on iPhone, web, ...
Any idea how to troubleshoot this further?
midd wrote:For those of you who installed homebridge buddy, did you attempt to install homebridge via Webdeck viewforum.php?f=191
and then install HomeBridge Buddy? I did and now I'm wondering if a combo of the two is bogging down the server.
