Simple way to show all methods/properties of a device?
Thu Jan 12, 2017 3:16 pm
superholz offline
I found it hard to find the right commands/properties of devices to use in python coding in the documetation.
Is there a simple way to print out all properties and methods a specific device supports?
Thu Jan 12, 2017 5:36 pm
Re: Simple way to show all methods/properties of a device?
Easiest way to see all properties is to open a scripting shell and:
dev = indigo.devices[DEVICEIDHERE] # "Some Device"
print dev
Seeing methods is harder. You can:
dir(dev)
Which shows all properties and methods, but you don't know which is which. The documentation is really the best way to see what methods there are and what they do.
Fri Jan 13, 2017 2:59 am
superholz offline
Hi thanks for the quick answer! Are all these parameters also available through python scripting? How would I, for example, get the value from "sensorValue.ui" to use it as string in a python script?
copied from below:
states : States : (dict)
batteryLevel : 60 (integer)
batteryLevel.ui : 60% (string)
sensorValue : 38.000000 (real)
sensorValue.ui : 38.0 °C (string)
>>> print dev
address : 24
allowOnStateChange : False
allowSensorValueChange : False
batteryLevel : 60
buttonGroupCount : 0
configured : True
description : Temperature
deviceTypeId : zwValueSensorType
displayStateId : sensorValue
displayStateImageSel : TemperatureSensor
displayStateValRaw : 38.0
displayStateValUi : 38.0 °C
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 418951730
com.perceptiveautomation.indigoplugin.zwave : (dict)
AllowSensorValueChange : false (bool)
SensorUnits : 1 (integer)
SupportsBatteryLevel : true (bool)
SupportsEnergyMeter : false (bool)
SupportsEnergyMeterCurPower : false (bool)
SupportsEnergyMeterReset : false (bool)
SupportsOnState : false (bool)
SupportsSensorValue : true (bool)
SupportsStatusRequest : true (bool)
address : 24 (integer)
disableStatusLogging : false (bool)
indigoObjVersion : 5 (integer)
modelNameAndFirmware : Temperature/Humidity Sensor (ST814), firmware 1.06 (string)
propsPushTickler : 7 (string)
tempAlwaysFalse : false (bool)
userConfigVal002 : 99 (integer)
userConfigVal003 : 99 (integer)
userConfigVal004 : 99 (integer)
userConfigVal005 : 99 (integer)
userConfigVal006 : 4 (integer)
userPollAfterActivity : true (bool)
userPollInterval : 0 (integer)
userPollingEnabled : true (bool)
userWakeInterval : 1440 (integer)
version : 1.06 (string)
zwAppVersMajor : 1 (integer)
zwAppVersMinor : 6 (integer)
zwAssociationsMap : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
zwAssociationsMapStr : 1:[1] 2:[] (string)
zwClassCmdBase : 49 (integer)
zwClassCmdMap : (dict)
c112 : 1 (integer)
c114 : 1 (integer)
c128 : 1 (integer)
c132 : 2 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c32 : 1 (integer)
c49 : 2 (integer)
c96 : 2 (integer)
zwClassCmdMapStr : 20v1 80v1 84v2 85v1 86v1 60v2 70v1 31v2 72v1 (string)
zwClassIds : (list)
Item : 4 (integer)
Item : 33 (integer)
Item : 1 (integer)
zwClassInstanceCountMap : (dict)
zwClassInstanceCountMapStr : - none - (string)
zwClassName : Multilevel Sensor (routing) (string)
zwConfigVals : (dict)
p2 : 99 (integer)
p3 : 99 (integer)
p4 : 99 (integer)
p5 : 99 (integer)
p6 : 2 (integer)
p7 : 0 (integer)
p8 : 0 (integer)
zwConfigValsStr : 2:99 3:99 4:99 5:99 6:2 7:0 8:0 (string)
zwDevEndPoint : 1 (integer)
zwDevSubIndex : 0 (integer)
zwEncryptionStatusStr : (string)
zwEndpointClassMap : (dict)
e1 : (list)
Item : 49 (integer)
e2 : (list)
Item : 49 (integer)
zwEndpointClassMapStr : 1:[31], 2:[31] (string)
zwEndpointDevTypeMap : (dict)
e1 : (list)
Item : 33 (integer)
Item : 1 (integer)
e2 : (list)
Item : 33 (integer)
Item : 1 (integer)
zwEndpointDevTypeMapStr : 1:(21 : 01), 2:(21 : 01) (string)
zwFeatureListStr : routing, battery, beaming, waking (string)
zwLibType : 6 (integer)
zwManufactureId : 96 (integer)
zwManufactureName : Everspring (string)
zwMeterSubTypeFlags : 0 (integer)
zwMeterSupportsReset : false (bool)
zwMeterType : 0 (integer)
zwModelDefnVers : 1 (integer)
zwModelId : 393217 (integer)
zwModelName : Temperature/Humidity Sensor (ST814) (string)
zwNodeNeighbors : (list)
Item : 1 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 7 (integer)
Item : 19 (integer)
Item : 20 (integer)
Item : 23 (integer)
zwNodeNeighborsStr : 1, 3, 4, 5, 7, 19, 20, 23 (string)
zwProtoVersMajor : 2 (integer)
zwProtoVersMinor : 64 (integer)
zwShowMainUI : true (bool)
zwShowManualModifyConfigParmUI : false (bool)
zwShowPollingUI : false (bool)
zwShowSubmitModelInfoUI : false (bool)
zwShowWakeIntervalUI : true (bool)
zwWakeInterval : 1440 (integer)
emptyDict : (dict)
lastChanged : 2017-01-13 09:11:36
lastSuccessfulComm : 2017-01-13 09:11:36
model : Temperature/Humidity Sensor (ST814)
onState : None
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
g1 : (list)
Item : 1 (integer)
g2 : (list)
c112 : 1 (integer)
c114 : 1 (integer)
c128 : 1 (integer)
c132 : 2 (integer)
c133 : 1 (integer)
c134 : 1 (integer)
c32 : 1 (integer)
c49 : 2 (integer)
c96 : 2 (integer)
zwClassIds : (list)
Item : 4 (integer)
Item : 33 (integer)
Item : 1 (integer)
p2 : 99 (integer)
p3 : 99 (integer)
p4 : 99 (integer)
p5 : 99 (integer)
p6 : 2 (integer)
p7 : 0 (integer)
p8 : 0 (integer)
e1 : (list)
Item : 49 (integer)
e2 : (list)
Item : 49 (integer)
e1 : (list)
Item : 33 (integer)
Item : 1 (integer)
e2 : (list)
Item : 33 (integer)
Item : 1 (integer)
Item : 1 (integer)
Item : 3 (integer)
Item : 4 (integer)
Item : 5 (integer)
Item : 7 (integer)
Item : 19 (integer)
Item : 20 (integer)
Item : 23 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : True
sensorValue : 38.0
subModel : Temperature
supportsAllOff : False
supportsOnState : False
supportsSensorValue : True
supportsStatusRequest : True
version : 1.06
Fri Jan 13, 2017 4:33 am
It depends on what type of value you want to access.
For a device property, you would use dev.PROPERTY:
>>> dev = indigo.devices[10496130]
>>> print dev.name
DS2408 Switch 0
>>> print dev.configured
True
For a device state, you would use dev.states['STATENAME']:
>>> print dev.states['owsPrimaryValue']
207
>>> print dev.states['owsType']
DS2408
For globalProps:
>>> dev.globalProps['DS2408PIOOutputLatchState']
u'254'
The above examples are from this device dict (it's helpful to post such things in a code block so that you can see the formatting):
address : FA0000000C56E529
batteryLevel : None
configured : True
description :
deviceTypeId : owsUserSwitch
displayStateImageSel : SensorOff
displayStateValRaw : 0.0
displayStateValUi : 0
enabled : False
errorState :
folderId : 1453848350
     com.fogbert.indigoplugin.OWServer : (dict)
          AllowOnStateChange : false (bool)
          DS2406PIOActivityLatchState : 255 (string)
          DS2406PIOOutputLatchState : 254 (string)
          DS2406PowerOnResetLatch : 1 (string)
          DS2406RSTZconfiguration : 0 (string)
          DS2408PIOActivityLatchState : 255 (string)
          DS2408PIOOutputLatchState : 254 (string)
          DS2408PowerOnResetLatch : 1 (string)
          DS2408RSTZconfiguration : 0 (string)
          SupportsOnState : true (bool)
          address : FA0000000C56E529 (string)
          prefSensorValue2408 : S_0 (string)
          romID : FA0000000C56E529 (string)
          serverList : 10.0.1.X (string)
lastChanged : 2016-04-07 09:36:04
lastSuccessfulComm : 2016-04-07 09:36:04
model : 8-Channel Addressable Switch (DS2408)
name : DS2408 Switch 0
onState : False
ownerProps : com.fogbert.indigoplugin.OWServer : (dict)
pluginId : com.fogbert.indigoplugin.OWServer
pluginProps : com.fogbert.indigoplugin.multitool : (dict)
protocol : Plugin
sensorValue : 0.0
     owsChannel : 0 (integer)
     owsFamily : 29 (string)
     owsHealth : 7 (real)
     owsInput1 : false (bool)
     owsInput2 : false (bool)
     owsInput3 : false (bool)
     owsInput4 : false (bool)
     owsInput5 : false (bool)
     owsInput6 : false (bool)
     owsInput7 : false (bool)
     owsInput8 : false (bool)
     owsPIOActivityLatchState : 255 (real)
     owsPIOLogicState : 207 (real)
     owsPIOOutputLatchState : 254 (real)
     owsPowerOnResetLatch : 1 (real)
     owsPrimaryValue : 207 (string)
     owsRSTZConfiguration : 0 (integer)
     owsRawData : CFFFFF00008800000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 (string)
     owsRomID : FA0000000C56E529 (string)
     owsType : DS2408 (string)
     owsVccPowerStatus : 1 (real)
     sensorValue : 0.000000 (real)
     sensorValue.ui : 0 (string)
subModel :
supportsOnState : True
version : None
So in answer to your original question...
>>> print dev.states['sensorValue.ui']
0
Fri Jan 13, 2017 3:39 pm
DaveL17 wrote:
For globalProps:
u'254'
Slight correction:
[code]>>> dev.globalProps['com.fogbert.indigoplugin.OWServer']['DS2408PIOOutputLatchState']
u'254'
[/code]
dev.globalProps is a dictionary of property dictionaries - one for each plugin that adds custom properties to the device. The properties for the owner of the device are identified by the plugin ID (as in the above example). There's also a shortcut however so you don't have to know what the plugin id is for the device owner:
>>> dev.ownerProps['DS2408PIOOutputLatchState']
u'254'
Fri Jan 13, 2017 4:46 pm
jay (support) wrote:
Slight correction:
u'254'
[/code]
u'254'
Thanks Jay. Not sure how I managed to foobar that one.
