Indigo Server disconnecting every night
Thu Jan 12, 2017 2:06 pm
oliverjhudson offline
Hey folks,
My Indigo server software is exiting every night, leaving me with the "start local server" dialog box on-screen.
System log shows:
Jan 12 02:46:06 mail IndigoServer[42441]: IndigoServer(42441,0xb1151000) malloc: *** mach_vm_map(size=1048576) failed (error code=3)
Jan 12 02:46:36 mail IndigoServer[42441]: IndigoServer(42441,0xb1151000) malloc: *** mach_vm_map(size=1048576) failed (error code=3)
Jan 12 02:46:49 mail IndigoPluginHost[42450]: connection to server failed or was dropped
Jan 12 02:46:49 mail IndigoPluginHost[42450]: Quiting Indigo Plugin Host - received quit signal
Jan 12 02:46:49 mail com.apple.xpc.launchd[1] (com.perceptiveautomation.indigo-server.3664[42441]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
Jan 12 02:46:49 mail IndigoPluginHost[42444]: connection to server failed or was dropped
This is happening at 0230-0245 every day with the same messages in the system log. There are no schedules or triggers set to run for that time.
Any ideas?
Thu Jan 12, 2017 2:30 pm
Re: Indigo Server disconnecting every night
Bad memory.
Thu Jan 12, 2017 3:02 pm
It could very well be bad memory. Your Mac might also be running out of memory. You can use the built-in Activity Monitor application to see if that is the case.
Mon Jan 16, 2017 2:10 pm
It doesn't seem to be the memory usage, but I replaced the server memory a few weeks ago - it could well be that. I'll run some hardware tests.
Thanks folks.
Thu Jan 25, 2018 8:31 am
DrLove offline
Did you get this sorted out? I have the "exact" behavior right now: http://forums.indigodomo.com/viewtopic.php?f=131&t=20062
I actutually get the exact same error as you: mach_vm_map(size=1048576) failed (error code=3)
Love Kull (yes it's my name)
Blog (in Swedish)
Sweden
Thu Jan 25, 2018 11:11 am
If you are using Indigo's built-in email scanning then try temporarily disabling that for a few days (via Indigo's preferences dialog) to see if that prevents the crash.
Thu Jan 25, 2018 12:23 pm
DrLove offline
Nope, not using email scanning :/
Blog (in Swedish)
Sweden
Fri Jan 26, 2018 2:05 am
This did resolve itself but I'm not sure why - I did have email scanning turned on and have subsequently turned it off (it doesn't play nicely with my server) so perhaps that was it...
It definitely wasn't a hardware change - still the same hardware!
Sat Jan 27, 2018 11:59 am
If you see the problem again then read over the new posts on this forum thread. It looks like for DrLove's case it was Indigo's email sending (not scanning) that was the culprit.
