"name of morning line" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
for both of my morning linc AFTER i did a sync:
- Code: Select all
PowerLinc Linking - entered discovery linking mode (240 seconds)
PowerLinc Linking - syncing PowerLinc links (address 3C.4B.FF)
PowerLinc Linking - . . adding: INSTEON plc link to controller 22.BF.93, flags 03, group 01, data 00 00 FF
PowerLinc Linking - . . adding: (not added -- probably already exists)
PowerLinc Linking - PowerLinc links updated
PowerLinc Linking - sync complete
PowerLinc Linking - sending engine version request to 22.BF.93
PowerLinc Linking - received engine version 02 from 22.BF.93
PowerLinc Linking - sending id request for device information to 22.BF.93
PowerLinc Linking - received id request response from 22.BF.93
PowerLinc Linking - initializing remote device "doorMorningLinc" (address 22.BF.93, firmware version 42)
PowerLinc Linking - initialize complete
PowerLinc Linking - syncing remote device "doorMorningLinc" (address 22.BF.93, firmware version 42)
PowerLinc Linking - syncing of this device not possible remotely (skipping)
PowerLinc Linking - exited linking mode
and :
- Code: Select all
Error "doorMorningLincBack" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
Error "doorMorningLinc" off; failed (PowerLinc not in module's database -- try the Define and Sync process in the device dialog)
still can can lock the doors, but not unlock
so everything started after I did a sync. before it was ok
