Everspring ST814 Temperature/Humidity Sensor problems
Fri Dec 02, 2016 5:21 pm
bek offline
Hi guys,
maybe my first post? Don't know/remember.
Well, I have a Everspring ST814 Temperature/Humidity Sensor since a couple of years. It has worked flawlessly a couple of years with Indigo6 and The Z-stick 2.
I upgraded to Indigo7 and did not notice any problems with it, but I am not shore since I did not give it any special treatment... It have just worked all the time before.
Then I last weekend upgraded my Z-stick to gen5 and re-synced all my devices. Everything went well. No errors and no problems. Just yesterday I noticed that it was getting cold (-7 degrees Celsius outside ) in my hobby room in the garage. I found out that the temperature and humidity statuses from my ST814 are not updated to Indigo7!
I am using the "Smart Devices" plugin with the ST814 as thermostat and two Fibaro Wall Plug Relays (FGWP101) are steering my two radiators. It has worked ok for about a year, no problems.
Now I have synced the ST814 several times with the same result: the sync goes through very well and everything seems good. BUT, the ST814 doesn't update anymore after the sync.
Indigos "Last update" does not wine about anything being wrong. It just seems that everything is ok? If I choose the ST814 and press "Send status request" I will get a red "no ack" status. So it seems somehow that the ST814 is dead after the "Define and sync..." procedure.
Any good thoughts what I should do now? I will also attach the sync log. No errors or problems are showing in the Event log for the ST814...
3 Dec 2016, 24:11.03
Z-Wave Syncing - started for "03 Temp Hobby room"
Z-Wave Syncing - retrieved module neighbors list: 2, 3, 4, 8, 9, 10
Z-Wave Syncing - assigning return route to "005 - 03 Temp Hobby room"
Z-Wave Syncing - retrieved manufacture and model names: Everspring - 0060, Temperature/Humidity Sensor (ST814) - 00060001
Z-Wave Syncing - retrieved protocol version 2.64, app version 1.06
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Multilevel Sensor : Multilevel Sensor (routing) (04 : 21 : 01, base 31)
Z-Wave Syncing - retrieved command classes: 20v1 80v1 84v2 85v1 86v1 60v2 70v1 31v2 72v1
Z-Wave Syncing - retrieved capabilities: routing, battery, beaming, waking
Z-Wave Syncing - retrieved wake interval of 30 minutes
Z-Wave Syncing - device "005 - 03 Temp Hobby room" wake interval changed to 30 minutes
Z-Wave Syncing - retrieved multi-endpoint types: 1:(21 : 01), 2:(21 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[31], 2:[31]
Z-Wave Syncing - retrieved parameter 2 "ON temperature trigger" is 99 degrees
Z-Wave Syncing - retrieved parameter 3 "OFF temperature trigger" is 99 degrees
Z-Wave Syncing - retrieved parameter 4 "ON humidity trigger" is 99 %
Z-Wave Syncing - retrieved parameter 5 "OFF humidity trigger" is 99 %
Z-Wave Syncing - retrieved parameter 6 "Reporting interval" is 5 minutes
Z-Wave Syncing - retrieved parameter 7 "Temperature reporting threshold" is 0 degrees
Z-Wave Syncing - retrieved parameter 8 "Humidity reporting threshold" is 0 %
Z-Wave Syncing - retrieved battery level of 60%
Z-Wave Syncing - complete
Z-Wave sent "03 Temp Hobby room" status request
Z-Wave sent "03 Humidity Sensor Hobby room" status request
Z-Wave received "03 Temp Hobby room" sensor update to 17.1 °C
Z-Wave received "03 Humidity Sensor Hobby room" sensor update to 39%
Living in Finland (The land of Kimi Räikkönen and Santa Claus) so therefore some kind of odd time in the log :-)
Fri Dec 02, 2016 5:47 pm
CrazyFin offline
Re: Everspring ST814 Temperature/Humidity Sensor problems
Terve Bek! :lol:
Country fellowman here (born in Sweden though but with both parents being from Finland)! 8)
I am on Indigo 7.0.2 with latest Z-Wave plugin 2.0.40 on a Mac Mini with an Aeon Labs S5 Gen 5 stick (my dev environment) and I have many (!!) of the ST814 devices.
I transferred one of my ST814 into my dev environment setup as described above and I tested with setting the reporting interval to 1 minute. I see temp and humidity updates in the log and the GUI every minute without problems so it it working quite nice over here (Stockholm, Sweden... 8) )
Fri Dec 02, 2016 7:33 pm
Try excluding it and re-including it to the Z-Stick, the re-syncing the new node ID.
If that doesn't help, then turn on debug Z-Wave logging via the Interfaces->Z-Wave->Configure menu item and let it run for 20 minutes or so, then copy/paste the Event Log results into a reply for me. Include the results of both the re-sync as well as the 20 minutes of waiting to see if it sends any data.
Sat Dec 03, 2016 5:02 am
CrazyFin offline
@Matt and Bek:
If it helps this is how the working ST814 is showing updates on my Mac Mini running 7.0.2 with Z-Wave plugin 2.0.40 and Aeon Labs S5 stick:
Temp update:
2016-12-03 01:44:01.751   Z-Wave Debug   RCVD requestVarSensorStatus: 01 0C 00 04 00 08 06 31 05 01 22 00 F8 16
2016-12-03 01:44:01.752   Z-Wave Debug   . .  requestVarSensorStatus: node 008, endpoint None, type 1, raw value 2200...
2016-12-03 01:44:01.753   Z-Wave Debug   . .  requestVarSensorStatus: 24.8 °C (float: 24.800000)
2016-12-03 01:44:01.753   Z-Wave   received "008 - Temperature (in lab on TV-server chassi)" sensor update to 24.8 °C
Humidity update:
2016-12-03 01:44:02.381   Z-Wave Debug   RCVD requestVarSensorStatus: 01 0B 00 04 00 08 05 31 05 05 01 14 D9
2016-12-03 01:44:02.383   Z-Wave Debug   . .  requestVarSensorStatus: node 008, endpoint None, type 5, raw value 0114...
2016-12-03 01:44:02.383   Z-Wave Debug   . .  requestVarSensorStatus: 20% (float: 20.000000)
2016-12-03 01:44:02.384   Z-Wave   received "008 - Humidity (in lab on TV-server chassi)" sensor update to 20%
Temp update:
2016-12-03 02:12:20.370   Z-Wave Debug   RCVD requestVarSensorStatus: 01 0C 00 04 00 08 06 31 05 01 22 00 F7 19
2016-12-03 02:12:20.372   Z-Wave Debug   . .  requestVarSensorStatus: node 008, endpoint None, type 1, raw value 2200...
2016-12-03 02:12:20.372   Z-Wave Debug   . .  requestVarSensorStatus: 24.7 °C (float: 24.700000)
2016-12-03 02:12:20.373   Z-Wave   received "008 - Temperature (in lab on TV-server chassi)" sensor update to 24.7 °C
Humidity update:
2016-12-03 02:12:21.035   Z-Wave Debug   RCVD requestVarSensorStatus: 01 0B 00 04 00 08 05 31 05 05 01 14 D9
2016-12-03 02:12:21.036   Z-Wave Debug   . .  requestVarSensorStatus: node 008, endpoint None, type 5, raw value 0114...
2016-12-03 02:12:21.037   Z-Wave Debug   . .  requestVarSensorStatus: 20% (float: 20.000000)
2016-12-03 02:12:21.037   Z-Wave   received "008 - Humidity (in lab on TV-server chassi)" sensor update to 20%
I am also attaching the debug inclusion log and debug sync log.
Everspring ST814 - Temp and humidity sensor - full inclusion and sync log in debug mode.txt
(13.98 KiB) Downloaded 132 times
Fri Apr 21, 2017 10:32 pm
jltnol offline
Ok so this is my first Z-Wave device. I have the Eversrping ST814, and a new Gen 5 Z-wave stick.
I've managed to enable the stick in Indigo as an interface. The stick flashes Blue, White, Red, then repeat.
I've removed it from my computer, pressed the button, the blue light flashes, then I press the C/F button on the ST814 three times. Things happen, the Linking icon flashes on the ST814, and then the stick continues to flash blue.
I plug the stick back into the computer, the stick goes back to the tricolor flash pattern, and I am able to create the ST814 as a Z-Wave device as non-encrypted in Indigo, both temp and humidity show up as separate devices. I note that the sensor is set to Cº, so I change it to Fº, then press the Send Status Request for the device, and the temp in Indigo changes from Cº to Fº. Likewise, I edit the Device Settings, and change the Wake Interval to 5 minutes, and press the Send Status Request in Indigo.
All is well.
Then a few minutes later, I press the Send Status Request in Indigo again, and communications fail. I'm sure I'm doing something wrong, but just am not sure what. The sensor is sitting right next to the computer during this entire series of events.
Sat Apr 22, 2017 12:48 pm
I think you are just seeing that the module is asleep (since it is battery powered). Thus the status request ("poll") of the device doesn't work unless you happen to wake the module first. The module should, however, periodically broadcast out the changes in the sensor values, so polling shouldn't really be needed.
Sat Apr 22, 2017 4:22 pm
jltnol offline
Yep yep
Kind of what I was thinking..
I searched the boards for other info, and there is a "reporting time" setting... default was never... or some other long interval. Re-set it to 2 mins... at least for the time being... and now all is well.
Lastly, since this is my first Z-Wave encounter, is it normal for the Z-Stick to cycle thru the three colors under normal use?
As always...
a huge THANKS!
Mon Apr 24, 2017 1:08 am
CrazyFin offline
I have all my ST814 set to 15 min reporting intervals and the wake up time to once a day. These settings helps to keep the battery life long (approx 1 year).
You can force a wake-up of the unit by triple-clicking the button marked with the square. The ST814 will then be awake for (I think) about 15-30 seconds in order to receive commands from Indigo if you want to change any of the settings.
Yepp this is normal when the Z-Stick is in normal operating mode.
Read more in the quick start guide and full manual at
Quick start guide: https://aeotec.freshdesk.com/support/so ... essentials
Full manual with engineering specs:
http://www.vesternet.com/downloads/dl/f ... manual.pdf
https://aeotec.freshdesk.com/support/so ... er-manual-
If you download and install the Z-Stick Gen5 backup software then there is a tick box for turning off the LED:
https://aeotec.freshdesk.com/support/so ... d-restore-
(The installation program is in Chinese but just run through the install as normally and when the program starts you have it in English.)
With the backup program you can:
1. Backup your Gen5 Z-Stick
2. Restore your setup from a previous backup
3. Set the power level
4. Turn the LED functionality on/off
5. Enable/Disable the security protocol
There is also the software IMA Tool (Installation and Maintenance Application Tool) that you can use to test network health and signal strength to each device in your Z-Wave network. Read more on the full manual page I linked to above. It can be somewhat tricky to find the IMA Tool on Aeotecs webpage. You have to download the "Z-Stick Gen5 UZB Drivers" zip-packag e and when you unzip the file you will get two folders where one of the folders is called "zensys-tools" and there you will find the IMA Tool (file is called ZWaveController.exe")
Here is the link: https://aeotec.freshdesk.com/support/so ... on-windows
Mon Apr 24, 2017 10:25 am
jltnol offline
This is very helpful. I'm not quite in my new house yet, but as I said, this was my first Z-Wave" test", and I was able to finally get it working.... no doubt info that will come in handy for the rest of the Z-Wave connection I'll have...
I'm going to download the tool, so when the time comes for final installation, I'll be further down the path than I am now.
Wed Jan 17, 2018 10:18 am
jltnol offline
So I'm trying to use the ST814 temp sensor as a trigger to enable or disable a schedule. I've got the schedule part of the script working fine, but am using this simpler script as a test... All this does is turn the device on... never off, regardless of the temps the sensor is reporting..
I'm guessing the IF statement is the problem, but am not sure. The script compiles correctly, and runs without any errors, but only turns the device ON. Right now, the outside temp is 19º (frozen south..), but when I click the RUN button, all that happens is the device turns on.
Any suggestions?
dev = indigo.devices[644159320] #ST814 temp ID
if dev.sensorValue <= "10":
   indigo.device.turnOn(1760428348)
if dev.sensorValue >= "11":
   indigo.device.turnOff(1760428348)
this is the code I've got, but all it does is turn on the device, regardless of the temp.
Wed Jan 17, 2018 10:27 am
Try:
if dev.sensorValue <= 10:
Note the use of 10 (an integer) rather than "10" (a string).
See if that works? :)
Wed Jan 17, 2018 11:19 am
jltnol offline
Well that worked out perfectly!
I didn't think about doing the "else" part... just the 2 different temps, but this seems easier and works perfectly.
Thanks for the help.
Cheers
Mon May 14, 2018 4:51 pm
jltnol offline
So things have been working swell, until I forgot to change the battery for 6 weeks.
Z-Wave communication is working ok, but now temp is reported as "%"...
May 14, 2018 at 5:47:45 PM
Z-Wave received "Outisde - Temperature" sensor update to 97.3 °F
Trigger T-115 Disable AM Temp Change
Z-Wave received "Outisde - Temperature" units changed to °F
Z-Wave received "Outisde - Temperature" sensor update to 23%
Z-Wave received "Outisde - Temperature" units changed to %
The device is measuring the right temp, but the last line has me confused.. :(. Humidity is begin reported correctly... but the temp is getting changed.. don't know why..
Mon May 14, 2018 7:56 pm
Try excluding it from the Z-Stick (or other controller), re-including it, then re-syncing it in Indigo.
Fri May 18, 2018 3:38 pm
jltnol offline
Hey Matt
Seems this may be written up as "operator error". I fiddle with the device itself, and finally got it to behave. I find the manual not very helpful, and found no mention of the behavior I was seeing... but regardless... its working now.
