[SOLVED]Cannot connect the Client
Fri Mar 28, 2014 11:15 am
hulmej offline
I am running the latest version on a networked Mac Mini running Mavericks. I cannot seem to get any of my other Macs to connect using the Indigo client. I have the Preferences set to allow remote access. It used to work in a prior version.
Not sure what to do next.
Fri Mar 28, 2014 3:34 pm
Re: Cannot connect the Client
A couple of things:
  • Make sure you have the right client on all of your Macs that are trying to connect to the server
  • Make sure the firewall on your server Mac is allowing the IndigoServer (/Library/Application Support/Perceptive Automation/Indigo 6/IndigoServer.app) to accept incoming connections
  • What exactly are the errors the clients are giving you when you specify the host IP and port (1176)?
Fri Mar 28, 2014 4:27 pm
hulmej offline
All Macs are running OS 10.9.2.
All Macs have Indigo 6.0.11 installed.
The Mini is running the server version
The Mini's firewall is set to allow incoming connections on Indigo 6.
All Macs can see the Mini and can reach it through its Screen Sharing or File Sharing.
However, the client Macs receive a message "Failed to connect to Indigo Server. The Indigo Server is either unreachable over the network or is not running." when I start the Indigo client.
Fri Mar 28, 2014 5:06 pm
Indigo 6 (the Mac client) or IndigoServer? It should be the latter and not the former.
Fri Mar 28, 2014 7:10 pm
hulmej offline
It is Indigo 6. Is there an IndigoServer that is a different application? I am under the impression that there is one application that can run as the server or a client, depending upon how it is installed and set up.
I have been running the full installation of Indigo on the Mac Mini, but installing only the client on my other Macs.
Fri Mar 28, 2014 9:57 pm
Yes, the IndigoServer.app is at the location I mentioned about 2 posts above (/Library/Application Support/Perceptive Automation/Indigo 6/IndigoServer.app).
Sat Mar 29, 2014 4:46 am
hulmej offline
I do not seem to have a "Perceptive Automation" folder in the Application Support folder. Nor is there a folder in Application Support for "Indigo"
Should I uninstall and reinstall?
Sat Mar 29, 2014 8:41 am
Are you looking in the correct library? It is the the library in your system root folder not the library under your user id. :)
Sat Mar 29, 2014 8:46 am
Correct, it's the Library folder at the top level of your hard drive, not the one in your user folder.
Sat Mar 29, 2014 9:48 am
hulmej offline
I see the IndigoServer app in the Perceptive Automation folder in Application Support in Library. I tried to open it, but nothing happened.
Indigo 6 server is running and the dialog box shows that it is set to allow remote connections.
Sat Mar 29, 2014 10:53 am
I think Jay was asking earlier if you had the Indigo Server App enabled in the firewall on the Mac mini?
You should have an entry in the firewall list like like this:
Sat Mar 29, 2014 11:32 am
hulmej offline
Thanks! That did the trick.
Sorry to be so dense.
