jaylender wrote:I'd love to finally get a solution to this problem. I'll send you the last letter in the old chain, if you get me an email address.
No need - we archive all email conversations, so I looked it up. Let me recap: you had two different user accounts on your Mac (neither of which Indigo created because we don't create accounts). You installed Indigo using one account, then switched to using the other one.
jaylender wrote:I think the general idea was that the remote server didn't approve of my changing my user profile on my computer, and refused to recognize connections from it, correct password be damned.
You aren't being totally honest here - we told you what the issue was but apparently you never did anything to correct the problem. This is not an Indigo issue but rather the fact that you switched from one user account to another and never fully merged the two. In fact:
from your email wrote:Okay, wow... I see that this problem has been going back a long way. Looks like the profile I've been using for more than a year is NOT attached properly to my .Mac identity, so downloads from the app store and elsewhere have been in the user folder from the older profile
We tried to help you work through it, but the fundamental issue is that you have serious file ownership/permission issues that go way beyond Indigo. Indigo didn't create the problem by doing anything "under the hood". The last reply from you seemed to indicate that you had things under control.
jaylender wrote:Additionally, for whatever reason, it was impossible to remove the old hooks and start over without a clean install, which I'm never going to undertake for this purpose.
No idea what you mean by "old hooks".
jaylender wrote:If you have come up with a way to do a plain old uninstall of YOUR software that can wipe the slate clean, that would be much appreciated.
Uninstalling Indigo is described in our documentation.
jaylender wrote:I think if Indigo is going to tinker under the hood of my system to make its remote reflector work, it should be able to undo that tinkering reliably.
Indigo does not "tinker under the hood" of your system. It installs files in the locations described above and does NOT change any system-level settings. We've described the problem for you and your last email implied that you had a handle on it.
This is what I'd try next: uninstall Indigo (save off your database file) following the directions above. If you're still using Indigo 5,
here are those directions. Note that the files that start with ~/Library are specific to the user account you've installed Indigo under but given the confused state of your user accounts you'll want to do it for
both accounts.
Before proceeding, decide which account you're actually using and
only use that account from this point forward. This seems to be the root of your issues. Run the
latest Indigo installer and move your database file back into the Databases folder (assuming Indigo 5 - change the 5 to a 6 if you're on Indigo 6):
/Library/Application Support/Perceptive Automation/Indigo 5/Databases/
Start Indigo by double-clicking on your database file. It will prompt you for your registration code so you'll need to have that handy. This process will completely reset Indigo on your Mac though it won't fix the other issues you have with multiple user accounts. When you get Indigo up and running, let us know because
we'll need to delete the old reflector (but leave the prism account) so you can start clean from that perspective as well. You'll log in to the goprism.com website and create your reflector then activate it as
described in the documentation.
