[SOLVED] Pro features not showing - but I have a pro licence
Wed Jan 29, 2014 4:51 am
Londonmark offline
I'm trying to use the "insert device state into variable" command which I have used before. However, when I create a schedule and go to Actions > Variable Actions, the only option I see is Modify Variable. The other options that should be there are missing.
I have a pro licence - confirmed by looking at the About Indigo 6 box - and am running 6.0.10. Any ideas?
LM
Wed Jan 29, 2014 10:08 am
Re: Pro features not showing - but I have a pro licence
Shut down the IndigoServer and quit the client, then rerun the Indigo installer.
Wed Jan 29, 2014 11:24 am
Londonmark offline
Jay,
I've tried exactly what you suggest (had done so before your post) but no luck. Still only shows "Modify variable" as the option under Actions > Variables.
LM
Wed Jan 29, 2014 3:56 pm
OK - stop the server and quit the client. Then start the client back up and copy/paste everything in the Event Log window into a followup post.
Wed Jan 29, 2014 4:46 pm
Londonmark offline
Here you go - looks as if it's something to do with the action collection plugin, but I cannot find the relevant file anywhere.
9 Jan 2014 22:45:34
Starting Indigo Server version 6.0.10
Loading attachments
"slimserver attachment.scpt" script loaded
Newer version of plugin ".Action Collection.indigoPlugin" v1.4.5 installed -- moving older version 1.4.4 to trash
Error failed to move file to trash (-5000), file path: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/.Action Collection.indigoPlugin
Error deleting file instead of moving it to the trash
Error ResolveDuplicatePlugins() caught exception: boost::filesystem::remove: Directory not empty: "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/.Action Collection.indigoPlugin"
Error ForceAlwaysEnabledPlugins() caught exception: FileIOError -- cannot move: destination file exists
Loading plugin "Action Collection 1.4.4"
Starting plugin "Action Collection 1.4.4" (pid 5400)
Loading plugin "LightwaveRF 1.0.4"
Starting plugin "LightwaveRF 1.0.4" (pid 5401)
Loading plugin "RFXCOM 1.3.6"
Starting plugin "RFXCOM 1.3.6" (pid 5402)
Disabling plugin "Action Collection 1.4.5"
Stopping plugin "Action Collection 1.4.5" (pid 5400)
Stopped plugin "Action Collection 1.4.5"
Found disabled interface "INSTEON Commands 2.0.4"
Found disabled interface "Z-Wave 1.0.187"
Found disabled plugin "Airfoil 1.1.4"
Found disabled plugin "Cynical Calendars 1.0.0b3"
Found disabled plugin "DIRECTV DVR Control 1.0.0"
Found disabled plugin "EasyDAQ Relay Card 1.1.4"
Found disabled plugin "Growl 1.1.1"
Found disabled plugin "iCal Alarm Processor 1.1.0"
Found disabled plugin "iTunes 1.1.4"
Found disabled plugin "NOAA Weather 1.1.0"
Found disabled plugin "SQL Logger 1.1.6"
Found disabled plugin "Timers and Pesters 1.1.3"
Found disabled plugin "Vera Bridge 1.0.5"
Found disabled interface "Virtual Devices 1.0.11"
Found disabled plugin "Weather Conditions 0.98"
Found disabled plugin "WeatherSnoop 2.0.1"
Bonjour registered "Indigo - My House"
Indigo Cocoa client connected
Started plugin "LightwaveRF 1.0.4"
LightwaveRF Debug startup called
Started plugin "RFXCOM 1.3.6"
RFXCOM Debug RFXCOM startup called
RFXCOM Debug startup called
RFXCOM Debug <<-- entering deviceStartComm: Chandelier (1182888782 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Chandelier, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Christmas tree (1793896191 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Christmas tree, type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Coffee (1495890428 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Coffee, type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Conservatory Lamp (426464016 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Conservatory Lamp, type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Conservatory switch (335871270 - LWSwitch)
RFXCOM Debug deviceStart called. Adding device Conservatory switch, type: LWSwitch
RFXCOM Debug Adding LightWave Switch housecode f0aeab and unitcode 16 (f0aeab16).
RFXCOM Debug <<-- entering deviceStartComm: Fairy lights (1473922040 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Fairy lights, type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Green remote button 1 (776938767 - LWRemote)
RFXCOM Debug deviceStart called. Adding device Green remote button 1, type: LWRemote
RFXCOM Debug Adding LightWave Remote housecode f1604e01 (f1604e01).
RFXCOM Debug <<-- entering deviceStartComm: Green remote button 2 (239264227 - LWRemote)
RFXCOM Debug deviceStart called. Adding device Green remote button 2, type: LWRemote
RFXCOM Debug Adding LightWave Remote housecode f1604e02 (f1604e02).
RFXCOM Debug <<-- entering deviceStartComm: Green remote button 3 (1513722698 - LWRemote)
RFXCOM Debug deviceStart called. Adding device Green remote button 3, type: LWRemote
RFXCOM Debug Adding LightWave Remote housecode f1604e03 (f1604e03).
RFXCOM Debug <<-- entering deviceStartComm: Hall Front (142576126 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Hall Front, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Hall Front Side (1351370763 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Hall Front Side, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Hall switch (510729835 - LWSwitch)
RFXCOM Debug deviceStart called. Adding device Hall switch, type: LWSwitch
RFXCOM Debug Adding LightWave Switch housecode f2ec31 and unitcode 16 (f2ec3116).
RFXCOM Debug <<-- entering deviceStartComm: Kitchen heater (1014129602 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Kitchen heater, type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Kitchen remote button 1 (1825784841 - LWRemote)
RFXCOM Debug deviceStart called. Adding device Kitchen remote button 1, type: LWRemote
RFXCOM Debug Adding LightWave Remote housecode f134f001 (f134f001).
RFXCOM Debug <<-- entering deviceStartComm: Kitchen remote button 2 (708896465 - LWRemote)
RFXCOM Debug deviceStart called. Adding device Kitchen remote button 2, type: LWRemote
RFXCOM Debug Adding LightWave Remote housecode f134f002 (f134f002).
RFXCOM Debug <<-- entering deviceStartComm: Kitchen remote button 3 (108873475 - LWRemote)
RFXCOM Debug deviceStart called. Adding device Kitchen remote button 3, type: LWRemote
RFXCOM Debug Adding LightWave Remote housecode f134f003 (f134f003).
RFXCOM Debug <<-- entering deviceStartComm: Kitchen thermometer (1421127947 - Temperature)
RFXCOM Debug deviceStart called. Adding device Kitchen thermometer, type: Temperature
RFXCOM Debug Adding sensor 606.
RFXCOM Debug <<-- entering deviceStartComm: Landing switch (317554741 - LWSwitch)
RFXCOM Debug deviceStart called. Adding device Landing switch, type: LWSwitch
RFXCOM Debug Adding LightWave Switch housecode f0b5be and unitcode 16 (f0b5be16).
RFXCOM Debug <<-- entering deviceStartComm: Living Room (73209627 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Living Room, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Living Room lamp (173575024 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Living Room lamp, type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Living Room lamp (RFX) (866724773 - LWAppliance)
RFXCOM Debug deviceStart called. Adding device Living Room lamp (RFX), type: LWAppliance
RFXCOM Debug <<-- entering deviceStartComm: Lower Stairs (1707224787 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Lower Stairs, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Mark Study Back (105032956 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Mark Study Back, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Mark Study Front (45043019 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Mark Study Front, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Middle stairs (56696547 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Middle stairs, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Moroccan 1 (1931913973 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Moroccan 1, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Moroccan 2 (744584219 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Moroccan 2, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Outdoor temp (725200393 - Temperature)
RFXCOM Debug deviceStart called. Adding device Outdoor temp, type: Temperature
RFXCOM Debug Adding sensor 1180.
RFXCOM Debug <<-- entering deviceStartComm: Pablo thermometer (1639139562 - Temperature)
RFXCOM Debug deviceStart called. Adding device Pablo thermometer, type: Temperature
RFXCOM Debug Adding sensor 395.
RFXCOM Debug <<-- entering deviceStartComm: PIR near front door (600268295 - LWSwitch)
RFXCOM Debug deviceStart called. Adding device PIR near front door, type: LWSwitch
RFXCOM Debug Adding LightWave Switch housecode 00b7c0 and unitcode 01 (00b7c001).
RFXCOM Debug <<-- entering deviceStartComm: Projector room (972161490 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Projector room, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Study lantern (138026820 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Study lantern, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Under stairs cupboard (1363088908 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Under stairs cupboard, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Uplighters (1512967132 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Uplighters, type: LWDimmer
RFXCOM Debug <<-- entering deviceStartComm: Upper stairs (1342313887 - LWDimmer)
RFXCOM Debug deviceStart called. Adding device Upper stairs, type: LWDimmer
RFXCOM Debug runConcurrentThread called
RFXCOM Debug startComm called
RFXCOM Debug getConfiguration start
RFXCOM initializing communication on port /dev/cu.usbserial-07VX4TMH at speed 38400
RFXCOM Debug serial port opened
RFXCOM Debug send reset cmd: 13 0 0 0 0 0 0 0 0 0 0 0 0 0 (0D 00 00 00 00 00 00 00 00 00 00 00 00 00)
WebServer client connected
WebServer started on port 8176 -- authentication disabled
RFXCOM Debug PIC INIT IS: none
RFXCOM Debug send init cmd: 13 0 0 1 2 0 0 0 0 0 0 0 0 0 (0D 00 00 01 02 00 00 00 00 00 00 00 00 00)
RFXCOM Debug rcvd init reply: 13 1 0 1 2 83 69 0 2 32 1 1 0 0 (0D 01 00 01 02 53 45 00 02 20 01 01 00 00)
RFXCOM connected to RFXtrx 433.92 MHz, firmware version 69
RFXCOM currently enabled receiver protocols: LightwaveRF, Oregon Scientific
RFXCOM enabling undecoded packet displaying
RFXCOM Debug send set mode cmd: 13 0 0 2 3 83 0 128 2 32 0 0 0 0 (0D 00 00 02 03 53 00 80 02 20 00 00 00 00)
RFXCOM Debug rcvd set mode reply: 13 1 0 2 3 83 69 128 2 32 1 1 0 0 (0D 01 00 02 03 53 45 80 02 20 01 01 00 00)
29 Jan 2014 22:45:37
Trigger Weather
RFXCOM Debug processing: 8 80 2 0 139 1 0 195 89 (08 50 02 00 8B 01 00 C3 59)
RFXCOM Debug Temp sensor 395 now 19.50 degrees and 0 humidity.
RFXCOM Debug Temp sensor 395 in list
RFXCOM Debug UpdateMinMax state temperature value 19.5
RFXCOM Debug check if new day: last date 2014/01/29, new date 2014/01/29
RFXCOM Debug UpdateMinMax state humidity value 0
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 8 80 2 1 94 2 0 136 137 (08 50 02 01 5E 02 00 88 89)
RFXCOM Debug Temp sensor 606 now 13.60 degrees and 0 humidity.
RFXCOM Debug Temp sensor 606 in list
RFXCOM Debug UpdateMinMax state temperature value 13.6
Trigger Set heaterstatus variable
Error unable to execute action -- device plugin "Action Collection" not enabled
Wed Jan 29, 2014 5:07 pm
Try stopping the Indigo Server, then empty your Mac OS X trash can and relaunch the Indigo Server.
Copy/paste the Event Log results of the start if that doesn't help.
Thu Jan 30, 2014 3:06 am
Londonmark offline
Still no luck. Here's the log.
30 Jan 2014 09:04:02
Loading attachments
Starting plugin "Action Collection 1.4.4" (pid 11991)
Starting plugin "LightwaveRF 1.0.4" (pid 11992)
Starting plugin "RFXCOM 1.3.6" (pid 11993)
Stopping plugin "Action Collection 1.4.5" (pid 11991)
Thu Jan 30, 2014 3:21 am
Londonmark offline
Jay - solved it by deleting the plugins directories and reinstalling.
Thu Jan 30, 2014 9:35 am
Re: [SOLVED] Pro features not showing - but I have a pro lic
Thanks for the follow-up. Seems like there was probably some permission issue on the files in those directories that was keeping Indigo from correctly deleting some stuff.
