[SOLVED]Action Collection not running
Sat Jan 04, 2014 12:36 pm
berkinet offline
I have occasionally experienced the same problem reported in this thread.
Indigo 6.0.4, MacOS 10.9
Any attempt to call the Action Plugin's actions results in:
    Error unable to execute action -- device plugin "Action Collection" not running
A restart clears the problem.
Note this server is in an unattended location so I tend to leave what works running until I can be onsite for upgrades.
Here is the startup log
    2014-01-04 00:13:05 Application Starting Indigo Server version 6.0.4
    2014-01-04 00:13:06 Application Loading attachments
    2014-01-04 00:13:06 Application "growl attachment.scpt" script loaded
    2014-01-04 00:13:33 Application Loading plugin "Action Collection 1.4.4"
    2014-01-04 00:13:33 Application Starting plugin "Action Collection 1.4.4" (pid 315)
    2014-01-04 00:13:33 Application Loading interface "INSTEON Commands 2.0.4"
    2014-01-04 00:13:33 Application Starting interface "INSTEON Commands 2.0.4" (pid 316)
    2014-01-04 00:13:33 Application Loading interface "Z-Wave 1.0.154"
    2014-01-04 00:13:33 Application Starting interface "Z-Wave 1.0.154" (pid 317)
    2014-01-04 00:13:33 Application Loading plugin "DSC Alarm 1.5.3"
    2014-01-04 00:13:33 Application Starting plugin "DSC Alarm 1.5.3" (pid 318)
    2014-01-04 00:13:33 Application Loading plugin "Growl 1.1.1"
    2014-01-04 00:13:33 Application Starting plugin "Growl 1.1.1" (pid 319)
    2014-01-04 00:13:33 Application Loading plugin "IP9258 1.1c"
    2014-01-04 00:13:33 Application Starting plugin "IP9258 1.1c" (pid 320)
    2014-01-04 00:13:33 Application Loading plugin "Meta Device 0.9.9"
    2014-01-04 00:13:33 Application Starting plugin "Meta Device 0.9.9" (pid 321)
    2014-01-04 00:13:33 Application Loading plugin "Netatmo Plugin 0.4.1"
    2014-01-04 00:13:33 Application Starting plugin "Netatmo Plugin 0.4.1" (pid 322)
    2014-01-04 00:13:33 Application Loading plugin "Phidgets Plugin 0.6.4"
    2014-01-04 00:13:34 Application Starting plugin "Phidgets Plugin 0.6.4" (pid 323)
    2014-01-04 00:13:34 Application Loading plugin "Proliphix Thermostat 1.9.8"
    2014-01-04 00:13:34 Application Starting plugin "Proliphix Thermostat 1.9.8" (pid 324)
    2014-01-04 00:13:34 Application Loading interface "Virtual Devices 1.0.10"
    2014-01-04 00:13:34 Application Starting interface "Virtual Devices 1.0.10" (pid 325)
    2014-01-04 00:13:34 Application Found disabled plugin "apcupsd 0.4.2"
    2014-01-04 00:13:34 Application Bonjour registered "Indigo - CasaMilagro"
    2014-01-04 00:13:45 Application Started interface "INSTEON Commands 2.0.4"
    2014-01-04 00:13:45 Application Started interface "Virtual Devices 1.0.10"
    2014-01-04 00:13:45 Application Started plugin "Growl 1.1.1"
    2014-01-04 00:13:46 Application Started plugin "IP9258 1.1c"
    2014-01-04 00:13:46 DSC Alarm Log level preferences are set to "Normal".
    2014-01-04 00:13:46 Application Started plugin "DSC Alarm 1.5.3"
    2014-01-04 00:13:49 DSC Alarm Your plugin version, v1.5.3, is current.
    2014-01-04 00:13:50 DSC Alarm Initializing communication at address: 192.168.5.36:4025
    2014-01-04 00:13:51 DSC Alarm Connected to Envisalink.
    2014-01-04 00:13:53 Reflector starting reflector connection to https://***********.goprism.com
    2014-01-04 00:14:06 Application WebServer client connected
    2014-01-04 00:14:06 WebServer started on port 8176 -- digest authentication enabled
    2014-01-04 00:14:23 WebServer access denied "http://******.*******.com:8176/" from ******* @ ***.***.***.***
    2014-01-04 00:15:03 Application Indigo Cocoa client connected
    2014-01-04 00:15:34 Application Connected to CM-11/HD-11 interface on port KeySerial1
    2014-01-04 00:15:34 Application CM-11 firmware version 8
    2014-01-04 00:16:00 Error unable to execute action -- device plugin "Action Collection" not running
Sat Jan 04, 2014 6:38 pm
Re: Action Collection not running
Upgrade to the latest version of Indigo 6 - we've added some more robust plugin restart logic.
