Troubleshooting "unauthorized access" in shortcut
Wed May 08, 2024 10:09 am
Re: Troubleshooting "unauthorized access" in shortcut
What does " Web Server Warning HTTP API v2 POST command received, id: '- no message id -' from 'redactedIP' mean?
Wed May 08, 2024 10:19 am
Two more things to check:
1) Make sure you have the Enable OAuth and API Key authentication enabled in the Start Local Server dialog
2) Make sure you didn't create a secrets file with the magic entry which would disable API keys
Wed May 08, 2024 10:39 am
I think either you or I posted at the very same time.
The short cut is working now, but I get that
message now. What does that mean?
Wed May 08, 2024 10:55 am
It’s just a security warning. The previous web server did it as well. There’s a setting in the advanced web server settings that lets you turn it off if you don’t want it.
Wed May 08, 2024 2:12 pm
Ah thanks. I think I'll leave it on. I was mainly concerned about the "no message id" part.
Wed May 08, 2024 3:03 pm
You can add a message ID to the API payload if you want -- it's good for identifying which thing fired the API call (WAN IP redacted below).
Web Server Warning              HTTP API v2 POST command received, id: 'Foyer Lamp Toggle Shortcut' from 'xxx.xxx.xxx.xxx'
Screenshot 2024-05-08 at 4.00.21 PM.png (45.97 KiB) Viewed 140 times
Wed May 08, 2024 3:07 pm
Awesome, thanks!
