Page 3 of 3
PostPosted: Sun Nov 08, 2009 7:37 pm
by masterbaron
Are you saying you can reach it via that URL on your iPod touch from Safari = yes
or are you on your Mac Safari? (try both please) = i can reach it from both
What happens if from Indigo Touch you create a new connection that looks like this:
i get very happy because it seems to be connecting consistently .. i'm trying different actions and in different order to see if i can get it to fail .. if not i guess the addition of the port number may make a difference ... i'll continue and let you know..
PostPosted: Sun Nov 08, 2009 7:45 pm
by masterbaron
i've powered down the touch and toggled to other apps ... i'm not getting the failure ... the bonjour names don't work but the ip & port id work ... could it be since i added port forwarding i must now use the 8176 port id to pass thru the router instead of server names or file sharing names hosted by bonjour???
very helpful either way Matt - thank you sir!
PostPosted: Mon Nov 09, 2009 9:03 pm
by matt (support)
Great -- glad we got this working! Something on your network is causing the Bonjour resolve to fail apparently. But I don't know if it is your router, its configuration, etc.
