Indigo Touch Broken on iOS 16 release
Thu Sep 15, 2022 7:41 pm
Re: Indigo Touch Broken on iOS 16 release
I had to restart the Indigo server to connect, but no issues after that. I don't use Indigo Touch very often, so it had been a long time since it was connected.
Sat Sep 17, 2022 10:01 am
If you are experiencing the crash:
• Please let us know which specific iOS hardware you are using.
• Try the following step: 1) uninstall, 2) reinstall, 3) re-launch and choose the Demo server. Does it crash? If so when/how?
Sun Sep 18, 2022 2:39 pm
rehafer offline
Same issue with iPhone 13, iOS16 recently installed. I get the opening screen with no devices. The app fails with any button press, so I can’t select server. I did uninstall and reinstall.
Sun Sep 18, 2022 2:43 pm
rehafer offline
Works fine on iPad mini 4. Same server (as far as I can tell)
Sun Sep 18, 2022 4:04 pm
veedubguy offline
Crashes any time I touch any button on the app. Uninstalled 3 times. Restarted iPhone each time. Reset network settings. Even force quit iPhone.
Running iOS 16.0. iPhone 12 Pro.
Sun Sep 18, 2022 4:10 pm
Tiago offline
:twisted:
I have also problems with Indigo Touch since iOS 16 update. And I've restored my iPhone. Indigo Touch still broken/blocked. Very bad. You need to produce I new version, simply...
iPhone 11 PRO 256Gb.
Sun Sep 18, 2022 5:33 pm
Different Computers offline
It's pretty clear the issues are peculiar and unique, rather than systemic.
Mon Sep 19, 2022 12:43 am
Tiago offline
It does not work.
Mon Sep 19, 2022 4:53 am
Just a quick note to remind folks that -- depending on your setup -- you can control Indigo via the Web as well. It's not an answer to the crashing issue, but it's a way to have control in the interim. For example,
https://10.0.1.123:8176
or
https://REFLECTOR_NAME.indigodomo.net
if you have an active subscription.
Mon Sep 19, 2022 11:10 am
If you are experiencing the crash then:
1) Update to iOS 16.0.1 if it is available on your phone to see if that helps.
2) Please email us (indigo-support AT indigodomo DOT com) any Indigo Touch crash reports. They can be found via Settings->Privacy & Security->Analytics & Improvements (near bottom)->Analytics Data. Search for Indigo and then use the top-right button to share the report with us via email.
Mon Sep 19, 2022 12:17 pm
Redrocker offline
Not yet available for my phone
Sent!
~Mark
Indigo 2021.2
Mon Sep 19, 2022 12:23 pm
Redrocker offline
As an FYI, no issues on iPad Air, latest version (but no OS update, so that makes sense).
~Mark
Indigo 2021.2
Tue Sep 20, 2022 8:17 am
Redrocker offline
Another note on this. It appears that there are several problems with iOS 16 and that Apple is aware. Reading some online articles, even iOS 16.0.1 doesn't address all of the problems, some much worse than Indigo Touch not functioning. I'll sit tight on this one, as I don't believe it's the application as much as it is the OS.
~Mark
Indigo 2021.2
Wed Sep 21, 2022 6:55 pm
MarcoGT offline
No issue in iPhone SE 3 with 16 beta something
Thu Sep 22, 2022 7:32 pm
gskarp offline
Upgraded to 16.02 and it broke it like it did for some of the others. iPhone 11 Pro Max
