blocked by Little Snitch
Wed Mar 21, 2018 6:38 pm
jrickmd offline
Installed Little Snitch onto my server as I had seen a couple of weird IP connections...
Indigo Touch is blocked by an irrevocable rule. A "code signing" issue. Here is a screenshot of the rule that Little Snitch creates (and recreates if I delete it) immediately upon an Indigo Touch attempted connection attached.
Thanks in advance for ideas.
Remote Desktop Picture March 21, 2018 at 7.26.46 PM CDT.png (128.18 KiB) Viewed 1713 times
Rick
Wed Mar 21, 2018 6:50 pm
Re: blocked by Little Snitch
That looks like an issue with your OS install - the Python executable is from Apple and should be signed by them.
Wed Mar 21, 2018 8:30 pm
You should be able to edit that rule to allow the connection. Or create an overriding rule. You can't just delete it.
What version of macOS are you running? And what version of Little Snitch? I'm not having any problems with Little Snitch blocking Indigo or Python.
Screen Shot 2018-03-21 at 10.35.28 PM.png (97.13 KiB) Viewed 1675 times
Thu Mar 22, 2018 4:29 pm
jrickmd offline
Thanks for responses. I did some online research and saw others having issues with Python. Tried to re-install python using those instructions I found. Can reinstall python, but not the Apple one. :roll:
Finally made a rule to ignore the certificates incoming AND outgoing for IndigoServer via Python.
El Cap 10.11.6 Latest little snitch 4.0.6
Remote Desktop Picture March 22, 2018 at 5.28.26 PM CDT.png (115.39 KiB) Viewed 1619 times
Rick
