I spoke to soon; the connection problem occurred again. It's so sporadic that it's hard to nail down.
mrmatt68 wrote:I cannot connect touch either and I have not updated to iOS 10. It has always worked with bonjour. I can't connect using ip either
jay (support) wrote:mrmatt68 wrote:I cannot connect touch either and I have not updated to iOS 10. It has always worked with bonjour. I can't connect using ip either
Have you tried this?
But 1 of my 3 iPads never had an issue on iOS10, so I realized I have 3 different Airport Extremes on a mesh network (all same SSID, hardwired together), so I figured they were connecting to different physical AEs. So I reset them all, and it seemed to work for awhile, but then crapped out again. For the record, I can still ping the IP of Mac Mini running Indigo Server from the iPad in question when the Indigo failures happen.
RogueProeliator wrote:But 1 of my 3 iPads never had an issue on iOS10, so I realized I have 3 different Airport Extremes on a mesh network (all same SSID, hardwired together), so I figured they were connecting to different physical AEs. So I reset them all, and it seemed to work for awhile, but then crapped out again. For the record, I can still ping the IP of Mac Mini running Indigo Server from the iPad in question when the Indigo failures happen.
There are similar reports on the web of this happening whenever multiple Airport Extremes are bridged together... behaving exactly as you describe. One such example:
https://discussions.apple.com/thread/1470067?start=0&tstart=0
You might could try using another Bonjour application whenever Indigo Touch fails -- see if, say, you can see a printer via Bonjour that is attached to another Airport Extreme (anything that uses Bonjour might be a valid test).
