Local connection issue with iOS 10
Fri Sep 16, 2016 7:46 am
rehafer offline
I encountered an issue where Touch can't connect locally, via Bonjour, to my server; but only occasionally.
At what appeares to be random intervals, Touch will time out while trying to connect to my server locally. On the settings screen, I can select my dynamic dns address and connect as normal. Also, if I delete the local connection from the list, in about 10 seconds it reappears and can connect as expected.
I'm assuming it is an iOS 10 issue because I don't remember it happening before updating. Maybe some new Bonjour protocol?
Fri Sep 16, 2016 2:44 pm
sumocomputers offline
Re: Local connection issue with iOS 10
Same exact here too on 3 iPad Minis that we use to control the entire house.
I may have to try and downgrade to iOS 9 quickly, unless a fix is on the way.
Fri Sep 16, 2016 3:15 pm
Can you, just for troubleshooting, turn the firewall on your Mac totally off? Restart the Indigo Server (not just the client) once it is OFF, then inside Indigo Touch delete the server settings line in the table and close/re-open the settings screen (gear icon). Does it then work?
Fri Sep 16, 2016 4:19 pm
I will try your suggestion on one iPad, and entering a manual IP:Port address on another. Currently using Bonjour discovery on all of them.
Sat Sep 17, 2016 8:55 am
So the Mac firewall was already off. And I completely restarted the Mac.
I have deleted the bonjour discovered servers from the Indigo touch list and reconnected one of the iPads to it, still same issue.
Entered IP:Port on another, still same issue.
I can confirm that the problem started immediately after upgrade to iOS 10.
One side note: On my iPhone 6+ running iOS 10, it never has a problem, but it is always accessed using a DynDNS style name, (like my_server.com:public_port).
Sat Sep 17, 2016 9:16 am
My iPhone 6S+ is connecting via Bonjour and seems to be connecting faster than ever. It feels like they did change something Bonjourish in iOS 10.
Sat Sep 17, 2016 9:25 am
I have only just launched Touch since my upgrade yesterday, in response to this thread - and I'd certainly agree with Dave's observation.
Sat Sep 17, 2016 11:00 am
I have reverted 2 of the 3 iPad Minis back to iOS 9.3.5, and I should know soon if it is any better.
I would say there is some anecdotal evidence pointing to iPad on iOS 10 not working, and iPhone on iOS 10 working fine.
I am wondering if it is some difference in the WiFi chip or stack that Apple changed.
Sat Sep 17, 2016 11:06 am
mat offline
I agree - 10 does feel/seem faster on Bonjour and I have patchy wifi while doing building work - unfortunately the better half just upgraded so I can't do a speed test.
Late 2018 mini 10.14
Sat Sep 17, 2016 4:25 pm
I can confirm that the iOS 9.3.5 units are working great after a few hours and the iOS 10.0.1 is still having issues (All iPad Mini 2).
Sat Sep 17, 2016 9:06 pm
aldera offline
I have an iPad mini 4 and an iPhone 6S on iOS 10 and they are both working fine.
Sat Sep 17, 2016 9:37 pm
rehafer,
What iOS devices have you seen the issue on? And what OS is running on the Mac?
Sun Sep 18, 2016 3:12 pm
citysnaps offline
I've been running Indigo Touch with 10.0.1 on my iPhone 6+ and so far have not found any issues connecting via Bonjour WiFi. Schedules, triggers, lights, motion sensors, cameras (via Cynical SecuritySpy), and iMessage alerts with photos appear to work fine.
Indigo touch.jpg (117.37 KiB) Viewed 3888 times
Brad
Urban photoblog: www.citysnaps.net
Mon Sep 19, 2016 7:23 pm
rehafer offline
[quote="sumocomputers"]rehafer,
I've noticed the issue on my iPhone 6s, I have an iPad but I used Touch on it less frequently and it leaves home less often so haven't noticed.
Mac OS 10.5 (early 2009 mini)
It may be coincidence but thinking about it I haven't experienced the problem since I updated Homebridge.
Mon Sep 19, 2016 8:40 pm
rehafer offline
Amazing how much clearer I think when I get home from work. The Homebridge-indigo update was to prevent Indigo from being overloaded by to many requests form iOS 10 HomeKit. Are you all running Homebridge or something else that may be bogging down Indigo and preventing bonjour connection?
