I have an issue with the device status refreshing correctly on control pages.
I am running Indigo Server 6.1.9 and iPad Mini 2s on iOS 9.3.2 with Indigo Touch 2.
I am having an issue that when device states are changed outside of the touch interface (like someone physically turns on a switch), the state on the touch interface is not always refreshed. I am using two different custom PNG images for control and feedback. Here is a screenshot of the button/feedback config:
https://www.dropbox.com/s/408a8cjf3jbmh ... 1.png?dl=0
The workaround is that I can go out and back into the control page, or simply send a refresh all device command. Here is a video that demonstrates the problem:
https://www.dropbox.com/s/zr4krxvjyclpg ... 1.mp4?dl=0
In the video above, the Kitchen & Living Room devices are actually on, and the Front Path is actually off. In this case I left the control page and came back, and all was good.
The embedded video feed which is a refreshing image URL is constantly updating in all cases, so I know the WiFi and connection to the Indigo server is working to some degree when the device state is not.
I could probably setup an "all device refresh" schedule every 5 or 10 minutes, but would rather solve the root issue.
Steps to reproduce:
1. Turn on a device directly like a SwitchLinc Relay with i2
2. Observe on iPad that device state is updated immediately
3. Let the iPad go to sleep
4. Turn off the SwitchLinc Relay device directly
5. Come back much later (like the next morning) and wake up/unlock the iPad
6. Observe that the true status is not reflected (still shows it is on)
7. Observe that the refreshing image feed is correctly streaming
