Sudden Connection Issues
Mon Sep 28, 2015 2:46 am
TOPS offline
Hi All,
Hope you can help, all of a sudden I am have trouble connecting to my server via Indigo Touch, Ive changed nothing, my server is on a static ip and relevant ports are open,
Any thoughts??
Dave
Mon Sep 28, 2015 2:56 am
Re: Sudden Connection Issues
Could you expand on your setup? Remote access, at home, via ip number, via indigo touch service, ...
Mon Sep 28, 2015 3:18 am
TOPS offline
Am using reflector service can connect with that over the web with no problem, touch just does not seem to want to connect
Cheers
Mon Sep 28, 2015 9:41 am
Wait - you have a static IP AND and a reflector? Why both?
Anyway, if the reflector connection is working, then the problem has to be related to your static ip connection in some way. Maybe your router is having some kind of issue with incoming traffic? What error do you see in Indigo Touch? If you just skip your static IP connection and use the reflector in Indigo Touch does that work?
Mon Sep 28, 2015 12:24 pm
TOPS offline
Hi Jay,
Thanks for the reply, I have a Static ip on my server mac not on my ISP, If I connect via the reflector everything is fine, if I launch Touch, it finds my server but can't connect, it asks for my Username and password, this I input correctly but no joy. I then tried to manually connect by inputing my MACs IP again I'm asked for UN & PW, I input the same and bingo I'm in but only from within my LAN, I can't connect from outside my LAN.
hope that makes sense
Cheers,
Dave
Mon Sep 28, 2015 3:27 pm
Are you sure you only have one Indigo Server running on your Network? It sounds like the bonjour server isn't the same as the one running on the IP you manually enter. That would be the only reason the username/password would work for one and not the other.
Wed Sep 30, 2015 12:32 pm
TOPS offline
Hi Jay,
Thanks for the reply, I only have one Indigo Server on my network, when I launch Indigo Touch no servers are found, I've quit the App, restarted it but no joy, I've I have all the boxes checked/unchecked on the Start Server box, i.e. allow remote access etc. I've checked my router and all the corresponding ports are open.
The only way I seem to be able to connect to my Server on my MAC is by the reflector in a web browser, however, yesterday I input my WAN ip? and the indigo port number into the "Manually Add Server" option in Touch and it worked (after inputing my un & pwrd) but now it does not work
Heelppp please, getting stressed out now
Regards,
Dave
Thu Oct 01, 2015 9:33 am
Try temporarily disabling the Firewall on your Mac, then restart the server and try again.
Thu Oct 01, 2015 10:19 am
TOPS offline
Hi Jay,
Tried that, no go I'm afraid :shock:
Cheers,
Dave
Thu Oct 01, 2015 10:59 am
Then, it's likely that your router is configured to block Bonjour (UPNP) traffic. Likewise, it sounds as if your router is behaving strangely since connections that sometimes work will then stop working.
Fri Oct 02, 2015 1:28 am
TOPS offline
Hi Jay,
I've looked at the settings in my router and UPNP is enabled, I can now access my Server from OUTSIDE my network by inputing my WAN IP and the Indigo Port number but these settings will not work from within my LAN although I can see and use the server from within my LAN with an iPad but not the iPhone, none of the devices see the Indigo Server.
Both iDevice are on iOS 9 with the latest update......Its driving me mad, considering it was working a few weeks ago and I've changed nothing.
Regards,
Dave
Fri Oct 02, 2015 9:38 am
What OS version are you running on your Mac?
Fri Oct 02, 2015 10:34 am
TOPS offline
Hi Jay
OSX Yosemite Version 10.10.5 (14F27)
Cheers
Dave
Sat Oct 03, 2015 11:18 am
TOPS offline
Hi Matt,
I've done nothing....but now everything seems to work ok, my server is being found by Touch from in and outside my LAN...."FULL CONTROL" has been reactivated....very strange :roll: :roll:
Cheers
Dave
Sat Oct 03, 2015 11:19 am
TOPS offline
Sorry Jay, I wrote Matt by mistake..... :oops:
