[ANSWERED]: Indigo Touch port forwarding
Fri May 01, 2015 10:16 am
Brandt offline
It's been a while since I've looked at this but on the Indigo 6.1.x Start Local Server view, I see:
Override Web server (HTTP) port number: (default 8176) (unchecked)
and down below I see:
Enable remote Indigo client access (checked)
Override Indigo Server port number: (default 1176) (unchecked)
I've been trying to connect Indigo Touch to 1176 with no luck.....
Just FYI from a user perspective, the 8176 option sounds like it's just for control pages, or maybe to access Indigo's own web server from a browser.
As far as I know, Indigo Touch is an Indigo client just as much as the client install on my desktop iMac is which makes me think to use 1176.
Indigo 7 w/ Dual-Band 2413U PLM
macOS High Sierra 10.13.x
2011 iMac 3.4 GHz Intel Core i7
Fri May 01, 2015 10:30 am
Re: Indigo Touch port forwarding
I normally just specify the ip address of the indigo server without a port number and that works. :)
Fri May 01, 2015 10:42 am
Brandt offline
Yes I understand that Indigo Touch with default to a certain port, but which port should be forwarded on the router?
It used to work with 1176, but not since updating to 6.1.x
Fri May 01, 2015 10:48 am
ah, ok - it is a router question - I will have to bow out as I don't know the answer - sorry :|
Fri May 01, 2015 10:49 am
Brandt offline
Not a router question as I know how to work with my router...just a "which port" question
Fri May 01, 2015 11:11 am
richo offline
For Touch it's also 8176
Sent using Tapatalk
Ryszard
Fri May 01, 2015 11:34 am
Brandt offline
According to
http://www.canyouseeme.org
Error: I could not see your service on xx.x.xxx.xx on port (xxxx)
Reason: Connection timed out
Although all my other port forwarding rules are working properly.
I've tried a few different ports for indigo, and my port forward rules and there are no services seen externally for indigo.
Fri May 01, 2015 1:09 pm
RogueProeliator offline
Mobile clients connect to Indigo via the web server -- you don't want to attempt to maintain a persistent connection with a mobile client; thus it routes through the standard web server on 8176.
Adam
Fri May 01, 2015 5:12 pm
Adam is correct – port 1176 is for the Mac Indigo client only. Indigo Touch and Web access all go through 8176.
Sun May 03, 2015 8:39 am
Re: [ANSWERED]: Indigo Touch port forwarding
If port 8176 isn't responding, then try turning off the Mac firewall completely just for troubleshooting.
Wed May 20, 2015 6:16 pm
thomasw offline
Hi Matt,
I did an upgrade from Leopard to Snow Leopard, leaving every program including Indigo 6 pro working. BUT, now Touch will not connect remotely? I turned off the Mac Firewall like you suggested and it works......... So, how would one go about getting the Mac OS to allow port 8176 to go to Indigo? Port 8176 is still setup fine in Indigo.
When I go to "Security" and Firewall, it still shows Indigo 6 as "allowed" as it has always been. Somehow this OS upgrade has stopped allowing Touch to remote into Indigo on port 8176?
Tom
Wed May 20, 2015 7:22 pm
thomasw offline
Never mind.
I found the problem.
In the Security/Firewall, there is Indigo 6 and ALSO 2 applications called "Python". You have to turn on "allow connections" from these to get Touch to connect on port 8176.
For some unknown reason, when I upgraded from Leopard to Snow Leopard, it turned "Python" off.
Now if the JERKS at Apple would fix Port Forwarding, and make it simple to just fill in the Port numbers you want to allow, it would make much more sense.
I suggest Indigo should take over Apple immediately. Matt and Jay would straighten them out.........LOL
