I've updated my guide - yes, it should be port 8176, I missed it when transcribing.
http://user:pass@192.168.x.y:8176/actions/NAME?_method=execute
Gary_BBGames wrote:... If you use the name:pass setting in the app it will use a basic base 64 encoded string as the Authorization value in the header. If you enter it in the URL field then it will be sent "as is". ...
autolog wrote:Should also have an underscore in front of method I think?
howartp wrote:Thanks. I suspected as much.Or a dyndns type service, but I've not tried that or looked at the implications of forwarding 8176 to Indigo from outside.
Gary_BBGames wrote:I'm open to implementing any suggestions you might think are useful.
autolog wrote:Some suggestions:It took me a while to get it working but the effort was worth it
- Check against Peter's summary post (has been updated in place with corrections since original posting)
- Make sure you haven't filled in the Name:Pass field under POST / PUT options
