- Posted on
Mon Mar 03, 2014 10:07 am
jay (support)
offline
- Site Admin
If you have stealth mode enabled on your Indigo Server Mac, that could be the reason bonjour never worked - it's under Firewall Options when you have it enabled.
If, however, you're iOS device is on the same network as your Mac and it's still not connecting, then you have some kind of network issue that's interfering with correct operation. Odd routing configurations, DMZs, etc., can all cause issues. We've never had a report of any network communication issues when entering IP addresses and port number directly that weren't solved by making sure that the router wasn't doing something odd and by disabling the Mac firewall (and even with it active as long as it's configured correctly it always seems to work).
What Mac OS X version are you using?
Note: Indigo 4 is no longer supported but we'll try to help with this issue nonetheless.
