- Posted on
Wed Aug 08, 2018 9:00 am
Different Computers
offline
You said you couldn't connect to the Indigo Server with the iPad, but you could for example surf the internet.
I want to make sure that you can surf the internet (=other connectivity) at the same time when you cannot contact the Indigo server. If, as I suspect, when you lose Indigo Touch connectivity, you lose all internet, the problem is not with Indigo.
Also, when you try to connect to the Indigo server, are you using an internal IP address?
