Can I use a variable for a refreshing image URL?
Mon Jun 01, 2015 3:42 pm
Londonmark offline
Can't find this anywhere (but maybe I've missed it). Can I use a variable for a refreshing image URL? I'm using the Sonos plugin and can populate a variable with the URL of the cover art. I then want to get that onto a control page. I could write a script to copy the url to a fixed file location, but that seems unnecessarily complicated...
Mon Jun 01, 2015 7:12 pm
Re: Can I use a variable for a refreshing image URL?
As far as I know, there's no way to use a variable in that way. Fortunately, for this purpose--you don't have to.
You can put cover art onto a control page using the following convention:
file:///Library/Application%20Support/Perceptive%20Automation/images/Sonos/kitchen_art.jpg
file:///Library/Application%20Support/Perceptive%20Automation/images/Sonos/office_art.jpg
file:///Library/Application%20Support/Perceptive%20Automation/images/Sonos/workshop_art.jpg
it will update to the image of the current item.
Dave
Mon Jun 01, 2015 7:57 pm
Dave is correct – that doesn't exist in Indigo currently. It is, however, on our feature request list.
Tue Jun 02, 2015 12:35 am
Londonmark offline
Thanks for the quick response. Just what I needed.
(Edited to remove a follow-up question that wasn't needed.)
Sat Oct 03, 2015 9:23 am
pacman offline
It took awhile to figure this out. Some information is missing regarding how to go from the Sonos plug-in inserting the URL (ZP_Art state) into a variable to getting the variable (ZP_Art URL) to update the "Refreshing Image URL" element on a web page. I used this simple AS:
set _Source to value of variable "SonosArt" as text --SonosArt is the variable name
end tell
tell application "Finder"
do shell script "curl _Source -o
file:///Library/Application%20Support/Perceptive%20Automation/images/Sonos/Library_art.jpg" --Library_art.jpg is the target file
end tell
I use a trigger to run the above script every time Sonos changes tracks (Device State Change)
Sat Oct 03, 2015 2:09 pm
pacman offline
Another note regarding this. I use snippets I find searching the internet and this forum so please poke holes in my last post as it is all trial and error. The script works as an embedded script, something I have tried to get away from. When I copy and paste the scrip into a new script file, add the external reference to IndigoServer, it does not work. It returns a shell script error.
tell application "IndigoServer" of machine "eppc://username:passwprd@192.168.0.66"
end tell
end tell
error "Finder got an error: curl: option -o: requires parameter
curl: try 'curl --help' or 'curl --manual' for more information
sh: line 1: file:///Library/Application%20Support/Perceptive%20Automation/images/Sonos/Library_art.jpg: No such file or directory" number 127
I think it doesn’t see “_Source” constant. Please help if you can. Thank you.
