Insteon Health Test Tool app now available
Mon Dec 09, 2013 12:23 am
Re: Insteon Health Test Tool app now available
same outcome:
....:~ karlwachs$ sleep 1;cd '/Users/karlwachs/Downloads/iHealth-1.2.app/Contents/Resources/';clear ; ./insteon_health.pl -d"/Users/karlwachs/Desktop/iHealth-Devices.txt" -i 10 -m cu.usbserial-A901M91S -o "/var/tmp/iHealth-Report.html";echo This window will automatically close in 30 seconds;sleep 30;exit
-bash: ./insteon_health.pl: /opt/local/bin/perl: bad interpreter: No such file or directory
logout
Mon Dec 09, 2013 12:31 am
berkinet offline
Ok... Then in a terminal window enter the command:
which perl
And post the results. We need to know the path to the perl interpreter installed on your system.
Mon Dec 09, 2013 8:20 am
/usr/bin/perl
Mon Dec 09, 2013 11:41 am
berkinet offline
Ok... try v1.3 on dropbox
Mon Dec 09, 2013 12:03 pm
here the result.
cd '/Users/karlwachs/Downloads/iHealth-1.3.app/Contents/Resources/';clear ; ./insteon_health.pl -d"/Users/karlwachs/Desktop/iHealth-Devices.txt" -i 10 -m cu.usbserial-A901M91S -o "/var/tmp/iHealth-Report.html";echo This window will automatically close in 30 seconds;sleep 30
dyld: lazy symbol binding failed: Symbol not found: _Perl_Gthr_key_ptr
Referenced from: ./CPAN/SerialPort.bundle
Expected in: dynamic lookup
dyld: Symbol not found: _Perl_Gthr_key_ptr
Trace/BPT trap: 5
Mon Dec 09, 2013 12:28 pm
berkinet offline
This is getting very odd... Ok, let's see which version of perl you are getting. Try this from the terminal
/usr/bin/perl -v
The first line is all I need. It should look something like:
    This is perl 5, version 16, subversion 2 (v5.16.2) built for darwin-thread-multi-2level
Mon Dec 09, 2013 1:35 pm
(with 3 registered patches, see perl -V for more detail)
this is osx 10.9 out of the box, nothing installed
Mon Dec 09, 2013 1:59 pm
berkinet offline
I am not sure how to proceed with this issue. I initially had the same issue you are seeing, but replacing the SerialPort module in the plugin fixed that, at least for me. So, it works here, but my installation is anything but custom and I can't really duplicate your environment. I have made a couple of adjustments that might help in v1.4. Get it from dropbox
It's probably time to rewrite this in Python.
Mon Dec 09, 2013 2:35 pm
got a bit farther..
dad-2:~ karlwachs$ sleep 1;cd '/Users/karlwachs/Desktop/iHealth-1.4.app/Contents/Resources/';clear ; ./insteon_health.pl -d"/Users/karlwachs/Desktop/iHealth-Devices.txt" -i 10 -m cu.usbserial-A901M91S -o "/var/tmp/iHealth-Report.html";echo This window will automatically close in 30 seconds;sleep 30;exit
Can't locate Device/SerialPort.pm in @INC (@INC contains: ./CPAN/auto ./CPAN/arch ./CPAN /Library/Perl/5.16/darwin-thread-multi-2level /Library/Perl/5.16 /Network/Library/Perl/5.16/darwin-thread-multi-2level /Network/Library/Perl/5.16 /Library/Perl/Updates/5.16.2 /System/Library/Perl/5.16/darwin-thread-multi-2level /System/Library/Perl/5.16 /System/Library/Perl/Extras/5.16/darwin-thread-multi-2level /System/Library/Perl/Extras/5.16 .) at ./insteon_health.pl line 30.
BEGIN failed--compilation aborted at ./insteon_health.pl line 30.
Mon Dec 09, 2013 3:32 pm
berkinet offline
Ok... Finally an error message I can act on ;-)
Try 1.5 on dropbox.
Mon Dec 09, 2013 5:27 pm
works.. thanks, still running, but web pages is building
Mon Dec 09, 2013 5:30 pm
berkinet offline
Great. Thanks for letting me know.. After a few other users try it (to resolve other potential issues) I'll get an update posted to the Contributions list.
BTW, If someone still on 10.8 or older would download the last version I posted and test it, that would be most helpful.
If you do. Please report here the MacOS version you used iHealth with.
Tue Dec 10, 2013 1:40 pm
got an error message at the end
Generating report:
Can't take sqrt of -1.04083e-17 at ./insteon_health.pl line 342, <LOG> line 183.
logout
then it stopped at that line. I guess that one was a non responding device.
There were 61 Insteon devices to test
using /dev/cu.usbserial-A901M91S
#################################### ITERATION 1 / 3 ####################################
                               spare micro   -   - - - - - - - - - - - - -
                           east LED lights   0.179   ***
                               SmokeBridge   0.170   ***
                 ExerciseRoomHallwayLights   0.172   ***
                                   imeter1   0.174   ***
                             Inst LED bulb   -   - - - - - - - - - - - - -
                               LampLink ??   -   - - - - - - - - - - - - -
                         pool temp io linc   -   - - - - - - - - - - - - -
                       outsideAlleyWayDoor   0.171   ***
                        KitchenTableLights   0.172   ***
                   FamilyRoomCeilingLights   0.170   ***
                      KitchenCeilingLights   0.172   ***
                    GameRoomCeilingLights2   0.173   ***
                 HallwayUpstairsBackLights   0.171   ***
                            PoolExitLights   0.205   ****
               outsideExerciseRoomLights??   0.171   ***
                              MasterbedFan   0.173   ***
                     JohannesCeilingLights   0.173   ***
                        ExerciseRoomLights   0.173   ***
                                Leo6Switch   0.171   ***
                     KitchenCeilingLights2   0.171   ***
                         KitchenWallLights   0.172   ***
                  outsideFrontBushesLights   0.172   ***
                      alleyWayOpen-close??   -   - - - - - - - - - - - - -
                           remote_8_button   -   - - - - - - - - - - - - -
                   outsidePoolLightsSwitch   0.177   ***
                     outsidePoolRoofLights   0.172   ***
                               StudyLights   0.233   ****
                                   Konsfan   0.173   ***
                           PoolExitLights2   0.173   ***
                    outsideFrontDoorLights   0.170   ***
                     outsideOutletPoolExit   0.174   ***
                           remote_4_button   -   - - - - - - - - - - - - -
                ExerciseRoomHallwayLights2   0.165   ***
                    outsideFrontEastLights   0.172   ***
                     GameRoomCeilingLights   0.173   ***
                           doorMorningLinc   0.171   ***
             DownstairsHallwayMiddleLights   0.170   ***
             DownstairsHallwayFamilyLights   0.173   ***
                                    LeoFan   0.171   ***
                outsideSwitchFrontBalkony    0.221   ****
                       outsideGarageLights   0.171   ***
                      HallwayUpstairsFront   0.171   ***
                      outsideKitchenLights   0.171   ***
                      GameRoomStairsLights   0.173   ***
            DownstairsHallwayFamilyLights2   0.174   ***
                     LeakSensorWashingRoom   -   - - - - - - - - - - - - -
                         StairsFrontLights   0.215   ****
                   LivingRoomCeilingLights   0.172   ***
                        StairsFrontLights2   0.171   ***
                       FamilyRoomSpotlight   0.170   ***
                  HallwayUpstairsMidLights   0.204   ****
                       LivingRoomSpotlight   0.173   ***
                   outsideGarageDoorOpener   0.172   ***
                   outsideGaragePoolOutlet   0.170   ***
                           MasterbedLights   0.170   ***
                     GameRoomStairsLights2   0.171   ***
                       doorMorningLincBack   0.172   ***
                 HallwayUpstairsMidLights2   0.203   ****
                               Kons6Switch   0.171   ***
                   DiningRoomCeilingLights   0.507   **********
#################################### ITERATION 2 / 3 ####################################
             DownstairsHallwayMiddleLights   0.177   ***
                   outsideGarageDoorOpener   0.171   ***
                 HallwayUpstairsBackLights   0.172   ***
            DownstairsHallwayFamilyLights2   0.172   ***
                      KitchenCeilingLights   0.180   ***
                  outsideFrontBushesLights   0.170   ***
                      outsideKitchenLights   0.252   *****
                    outsideFrontEastLights   0.166   ***
                     GameRoomCeilingLights   0.172   ***
                                    LeoFan   0.170   ***
                           east LED lights   0.171   ***
                     outsideOutletPoolExit   0.172   ***
                        KitchenTableLights   0.171   ***
                         KitchenWallLights   0.170   ***
                      HallwayUpstairsFront   0.174   ***
                                   Konsfan   0.172   ***
                               Kons6Switch   0.173   ***
                                   imeter1   0.174   ***
                ExerciseRoomHallwayLights2   0.522   **********
                outsideSwitchFrontBalkony    0.267   *****
                  HallwayUpstairsMidLights   0.207   ****
                     JohannesCeilingLights   0.172   ***
                 HallwayUpstairsMidLights2   0.187   ***
                               StudyLights   0.461   *********
                       doorMorningLincBack   0.171   ***
                           doorMorningLinc   0.173   ***
                 ExerciseRoomHallwayLights   0.170   ***
                           MasterbedLights   0.173   ***
                            PoolExitLights   0.173   ***
                     outsidePoolRoofLights   0.169   ***
                               SmokeBridge   0.169   ***
                              MasterbedFan   0.166   ***
                       LivingRoomSpotlight   0.165   ***
                   outsidePoolLightsSwitch   0.169   ***
                           PoolExitLights2   0.171   ***
                   DiningRoomCeilingLights   0.508   **********
                     KitchenCeilingLights2   0.170   ***
               outsideExerciseRoomLights??   0.173   ***
                    outsideFrontDoorLights   0.171   ***
                   outsideGaragePoolOutlet   0.172   ***
                      GameRoomStairsLights   0.172   ***
                         StairsFrontLights   0.204   ****
#################################### ITERATION 3 / 3 ####################################
                   DiningRoomCeilingLights   0.228   ****
                      HallwayUpstairsFront   0.173   ***
             DownstairsHallwayFamilyLights   0.171   ***
                      GameRoomStairsLights   0.174   ***
                 ExerciseRoomHallwayLights   0.171   ***
                      KitchenCeilingLights   0.173   ***
                   FamilyRoomCeilingLights   0.173   ***
                  HallwayUpstairsMidLights   0.172   ***
                        KitchenTableLights   0.173   ***
                       LivingRoomSpotlight   0.172   ***
                      outsideKitchenLights   0.173   ***
                       outsideAlleyWayDoor   0.165   ***
                           PoolExitLights2   0.172   ***
                        ExerciseRoomLights   0.168   ***
                    outsideFrontEastLights   0.217   ****
                   outsideGarageDoorOpener   0.173   ***
                     KitchenCeilingLights2   0.180   ***
                            PoolExitLights   0.174   ***
                              MasterbedFan   0.168   ***
                           east LED lights   0.172   ***
                  outsideFrontBushesLights   0.171   ***
                outsideSwitchFrontBalkony    0.222   ****
                    GameRoomCeilingLights2   0.167   ***
                 HallwayUpstairsMidLights2   0.204   ****
                                    LeoFan   0.172   ***
               outsideExerciseRoomLights??   0.172   ***
                    outsideFrontDoorLights   0.174   ***
                           doorMorningLinc   0.183   ***
                               Kons6Switch   0.172   ***
                       doorMorningLincBack   0.170   ***
                         StairsFrontLights   0.171   ***
                ExerciseRoomHallwayLights2   0.171   ***
                                   Konsfan   0.172   ***
                                Leo6Switch   0.172   ***
                     outsideOutletPoolExit   0.171   ***
                     JohannesCeilingLights   0.171   ***
             DownstairsHallwayMiddleLights   0.171   ***
                                   imeter1   0.173   ***
                       FamilyRoomSpotlight   0.522   **********
                       outsideGarageLights   0.170   ***
                               StudyLights   0.235   ****
                   outsidePoolLightsSwitch   0.172   ***
                         KitchenWallLights   0.171   ***
##########    Report for: /var/tmp/iHealth_logs/20131210_133119  ##########
Per-device statistics:                name   success   min   avg   max   stdev   avg
                   DiningRoomCeilingLights     3   0.228   0.414   0.508   0.132   ********
             DownstairsHallwayFamilyLights     3   0.171   0.172   0.173   0.001   ***
            DownstairsHallwayFamilyLights2     3   0.172   0.173   0.174   0.001   ***
             DownstairsHallwayMiddleLights     3   0.170   0.173   0.177   0.003   ***
                 ExerciseRoomHallwayLights     3   0.170   0.171   0.172   0.001   ***
                ExerciseRoomHallwayLights2     3   0.165   0.286   0.522   0.167   *****
                        ExerciseRoomLights     3   0.168   0.171   0.173   0.002   ***
                   FamilyRoomCeilingLights     3   0.170   0.171   0.173   0.001   ***
                       FamilyRoomSpotlight     3   0.170   0.287   0.522   0.166   *****
                     GameRoomCeilingLights     3   0.172   0.173   0.173   0.000   ***
                    GameRoomCeilingLights2     3   0.167   0.171   0.173   0.003   ***
                      GameRoomStairsLights     3   0.172   0.173   0.174   0.001   ***
                     GameRoomStairsLights2     3   0.171   0.171   0.171   0.000   ***
                 HallwayUpstairsBackLights     3   0.171   0.171   0.172   0.000   ***
                      HallwayUpstairsFront     3   0.171   0.173   0.174   0.001   ***
                  HallwayUpstairsMidLights     3   0.172   0.194   0.207   0.016   ***
                 HallwayUpstairsMidLights2     3   0.187   0.198   0.204   0.008   ***
                             Inst LED bulb     0   2.500   2.500   2.500   0.000   **************************************************
                     JohannesCeilingLights     3   0.171   0.172   0.173   0.001   ***
                      KitchenCeilingLights     3   0.172   0.175   0.180   0.004   ***
                     KitchenCeilingLights2     3   0.170   0.174   0.180   0.004   ***
                        KitchenTableLights     3   0.171   0.172   0.173   0.001   ***
                         KitchenWallLights     3   0.170   0.171   0.172   0.001   ***
                               Kons6Switch     3   0.171   0.172   0.173   0.001   ***
                                   Konsfan     3   0.172   0.172   0.173   0.000   ***
                               LampLink ??     0   2.500   2.500   2.500   0.000   **************************************************
                     LeakSensorWashingRoom     0   2.500   2.500   2.500   0.000   **************************************************
                                Leo6Switch     3   0.171   0.171   0.172   0.000   ***
                                    LeoFan     3   0.170   0.171   0.172   0.001   ***
Thu Dec 12, 2013 8:57 pm
Len Evansic offline
This newest version does now work on Mavericks, but I ran into a new problem. When building a new device list, the tool included my new hidden door sensor, which is wireless. Not sure what info you need to exclude that type of sensor.
This is the entry in my device list:
Device: Front Door
Description:
Type: insteon
Model: Door Sensor
Address: 2B.0D.D8
-- Len
Fri Dec 13, 2013 12:06 am
berkinet offline
The easiest way to deal with devices you don't want tested is to just edit the saved device file to remove the description of the offensive device. You can then keep on using that file (it's faster than building it each time anyway).
I can update iHealth to delete them from the scan. However, if I do that I'd want to add all of the newer Insteon devices that are non-responsive to pings (mostly wireless I guess). However, there are a lot of those and I have no idea what they are. Jay, Matt... can you send me a list of Insteon model names that are not normally awake to be queried.
