restarting Motorola SB6121 cable modem through a script
Sat Jan 25, 2014 1:30 am
for those who would like to restart their cable modem remotely:
the following command will reboot your cable modem. the address 192.168.100.1 is hardwired into the modem it does not change
in a terminal:
curl http://192.168.100.1/reset.htm?&reset_modem=Restart%20Cable%20Modem
in applescript:
do shell script "curl http://192.168.100.1/reset.htm?&reset_modem=Restart%20Cable%20Modem"
in PY:
subprocess.Popen( "curl http://192.168.100.1/reset.htm?reset_modem=Restart%20Cable%20Modem",shell=True,stdout=subprocess.PIPE,stderr=subprocess.PIPE).communicate()
just use your browser to get to the status page at 192.168.100.1
It shows signal levels, log files and also the reset button that is triggered by above commands.
