Conversion of Event Log Error Script to Python 3
Tue May 24, 2022 8:22 pm
GRWilde offline
I am having difficulty converting the following Python 2 script to Python 3. This script finds all Event Log errors and emails the results. I have changed the print theBody to print(theBody) but then the following error occurs. Any ideas how to fix this script are appreciated.
"Script Error embedded script error:
Script Error 'ascii' codec can't decode byte 0xc2 in position 7915: ordinal not in range(128)
embedded script, line 15, at top level
File '/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/encodings/ascii.py', line 26, in decode
return codecs.ascii_decode(input, self.errors)[0]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 7915: ordinal not in range(128)"
import os
from datetime import date
baseDir = indigo.server.getInstallFolderPath()
tmpFileName = os.path.join(baseDir, 'Logs/tmp.txt')
fileDate = str(date.today())
eventFileName = os.path.join(baseDir, 'Logs/' + fileDate + ' Events.txt')
theBody = ''
with open(tmpFileName, 'a') as tmpFile:
    with open( eventFileName, 'r' ) as log:
        for line in log:
            if 'Error' in line:
               tmpFile.write(line)
               theBody += line
# theBody is the body of  an email which is sent next
print theBody
indigo.variable.updateValue(1155409051, value=theBody)
theSubject = "All Indigo Event Log Errors"
indigo.variable.updateValue(1695073597, value=theSubject)
George Wilde
Tue May 24, 2022 8:58 pm
Re: Conversion of Event Log Error Script to Python 3
Try this. In Python 3, strings are unicode, not bytes. But file IO is bytes. So you need to encode your string when you write it to a file.
import os
theBody = ''
        for line in log:
            if 'Error' in line:
               tmpFile.write(line.encode('UTF-8'))
               theBody += line
print theBody
Tue May 24, 2022 9:02 pm
It might also be the line before, where you're looking for a string in the line read from the file. You could try changing that line to:
            if b'Error' in line:
Which forces that string to a bytestring, which is same type as the file input buffer (line).
I haven't done much File IO in Python3, so I'm not sure the best way to do this.
Tue May 24, 2022 9:03 pm
See https://docs.python.org/3/tutorial/inpu ... ting-files
Adding the file encoding to the file open will handle most of the conversion by itself.
Wed May 25, 2022 3:07 am
GRWilde offline
Thanks for the suggestion. It solved my problem just by including the encoding in the open file statement, namely:
with open(tmpFileName, 'a', encoding="utf-8") as tmpFile:
with open( eventFileName, 'r', encoding="utf-8") as log:
I run this script every evening to receive an email showing all Indigo errors that occurred during the day.
George Wilde
