download a file to a given path
Fri Mar 30, 2018 10:39 am
haavarda offline
Is there anyone that know of a script that will download a file in a url to a location on the mac?
I have a url that contains a mp3, and I want to store that mp3 file in a folder on my mac. If there already is a file there, I want to replace it.
Håvard
Fri Mar 30, 2018 10:48 am
Colorado4Wheeler offline
Re: download a file to a given path
You could try this (not knowing your exact circumstances, just assumptions):
import os
import requests
url = "http://your_file_location_url"
path = "/users/myloginname/Documents/stuff i downloaded"
data = requests.get(url).content
if os.path.exists (path):
   with open(path + "/filename.txt", 'w') as file_:
      file_.write (data)
   file_.close()
Fri Mar 30, 2018 11:14 am
FYI, the close() call is unnecessary (and I think as written it may actually throw an exception) since you opened it inside a with block. Fun fact which I didn't know until recently, you can actually open multiple files in the same with statement:
with open(newfile, 'w') as outfile, open(oldfile, 'r', encoding='utf-8') as infile:
And once the block ends all files will be closed automatically.
Fri Mar 30, 2018 11:19 am
haavarda offline
Thanks. That worked exactly as I was hoping. The first one that is. :)
It also works when I remove the close part...
Håvard
Fri Mar 30, 2018 1:10 pm
Old school techniques still prevail. :D
It shouldn't because the variable is declared and alive, I use this method most of the time without error. Of course if I don't need Close() then it's not needed anyway.
That's pretty cool. There's a lot of those shortcuts I've never taken the time to brush up on because I have such seldom need for them.
