Husqvarna Automower Script
Mon Sep 05, 2016 1:29 pm
Gusten offline
Here is a couple of script to control your Husqvarna Automower (With the Connect option)
I am running these scripts as "Execute script" and then linked it as a file.
First of all, i have used this as the starting point when modifying the script.
https://github.com/chrisz/pyhusmow
There are for better way for sure to do this, but this work.
You need requests and xmltodict installed first
You also need to enter your mail and password in the script see the line that start with mow.login
This is the script for starting the mower (Use the same script for stopping and for parking, just change the command in the script, change the line that start with mow.control)
import requests
import xmltodict
class API:
    _API_IM = 'https://tracker-id-ws.husqvarna.net/imservice/rest/'
    _API_TRACK = 'https://tracker-api-ws.husqvarna.net/services/'
    def __init__(self):
        self.session = requests.Session()
        self.device_id = None
        self.push_id = None
    def login(self, login, password):
        request = ("<login>"
                   "  <email>%s</email>"
                   "  <password>%s</password><language>fr-FR</language>"
                   "</login>") % (login, password)
        response = self.session.post(self._API_IM + 'im/login',
                                     data=request, headers={'Content-type': 'application/xml'})
        response.raise_for_status()
        self.session.headers.update({'Session-Token': response.headers['Session-Token']})
        self.select_first_robot()
    def logout(self):
        response = self.session.post(self._API_IM + 'im/logout')
        del (self.session.headers['Session-Token'])
    def list_robots(self):
        response = self.session.get(self._API_TRACK + 'pairedRobots_v2')
        result = xmltodict.parse(response.content)
        return result
    def select_first_robot(self):
        result = self.list_robots()
        self.device_id = result['robots']['robot']['deviceId']
    def status(self):
        response = self.session.get(self._API_TRACK + 'robot/%s/status_v2/' % self.device_id)
        return result
    def geo_status(self):
        response = self.session.get(self._API_TRACK + 'robot/%s/geoStatus/' % self.device_id)
        return result
    def get_mower_settings(self):
        request = ("<settings>"
                   "    <autoTimer/><gpsSettings/><drivePastWire/>"
                   "    <followWireOut><startPositionId>1</startPositionId></followWireOut>"
                   "    <followWireOut><startPositionId>2</startPositionId></followWireOut>"
                   "    <followWireOut><startPositionId>3</startPositionId></followWireOut>"
                   "    <followWireOut><startPositionId>4</startPositionId></followWireOut>"
                   "    <followWireOut><startPositionId>5</startPositionId></followWireOut>"
                   "    <followWireIn><loopWire>RIGHT_BOUNDARY_WIRE</loopWire></followWireIn>"
                   "    <followWireIn><loopWire>GUIDE_1</loopWire></followWireIn>"
                   "    <followWireIn><loopWire>GUIDE_2</loopWire></followWireIn>"
                   "    <followWireIn><loopWire>GUIDE_3</loopWire></followWireIn>"
                   "    <csRange/>"
                   "    <corridor><loopWire>RIGHT_BOUNDARY_WIRE</loopWire></corridor>"
                   "    <corridor><loopWire>GUIDE_1</loopWire></corridor>"
                   "    <corridor><loopWire>GUIDE_2</loopWire></corridor>"
                   "    <corridor><loopWire>GUIDE_3</loopWire></corridor>"
                   "    <exitAngles/><subareaSettings/>"
                   "</settings>")
        response = self.session.post(self._API_TRACK + 'robot/%s/settings/' % self.device_id,
        return result
    def settingsUUID(self):
        response = self.session.get(self._API_TRACK + 'robot/%s/settingsUUID/' % self.device_id)
        return result
    def control(self, command):
        if command not in ['PARK', 'STOP', 'START']:
            raise Exception("Unknown command")
        request = ("<control>"
                   "   <action>%s</action>"
                   "</control>") % command
        response = self.session.put(self._API_TRACK + 'robot/%s/control/' % self.device_id,
    def add_push_id(self, id):
        request = "id=%s&platform=iOS" % id
        response = self.session.post(self._API_TRACK + 'addPushId', data=request,
                                     headers={'Content-type': 'application/x-www-form-urlencoded; charset=UTF-8'})
        self.push_id = id
    def remove_push_id(self):
        response = self.session.post(self._API_TRACK + 'removePushId', data=request,
        self.push_id = None
if __name__ == '__main__':
    retry = 5
    while retry > 0:
            mow = API()
            mow.login("mail@mail.com", "your password")#Here you need to enter your mail and password
            mow.control("START")#Change the word START to STOP or PARK depending of what your command should be
            retry = 0
        except Exception as ex:
            retry -= 1
            if retry == 0:
                print("[ERROR] Retrying to send the command")
                print("[ERROR] Failed to send the command")
                exit(1)
    indigo.server.log("Done")
    mow.logout()
Mon Sep 05, 2016 1:44 pm
Gusten offline
Re: Husqvarna Automater Script (The status script)
And here are the script to collect status and put in variables
(I don't know if Husqvarna has some limitations to how often you can collect the status, i run this script every 40sec when the mower is cutting, and once an hour when charging. Its on your one risk)
You will need to enter your mail and password in this as well
And you need to make four variables before running this script
(You can name them what you like)
They will output
Status
Longitude
Latitude
batteri from 0-100
Use the Variable ID and change them in the script where the lines tart with indigo.variable.updateValue
import requests
import xmltodict
class API:
    def __init__(self):
        self.push_id = None
    def logout(self):
        return result
    def status(self):
        return result
        return result
                   "    <csRange/>"
                   "</settings>")
        return result
        return result
        self.push_id = id
        self.push_id = None
    retry = 5
    while retry > 0:
            mow = API()
            mow.login("mail@mail.com", "your password")#here you need to enter your mail and password
            dic_info = dict(mow.status()['mowerInfo'])
            mowerStatus = dic_info.get('mowerStatus')
            batteryPercent = dic_info.get('batteryPercent')
            latitude = dic_info.get('latitude')
            longitude = dic_info.get('longitude')
            indigo.variable.updateValue(214675392, value=mowerStatus)#change the 214675392 to your indigo variable ID
            indigo.variable.updateValue(1295626237, value=batteryPercent)#change the 1295626237 to your indigo variable ID
            indigo.variable.updateValue(1958242952, value=unicode(latitude))#change the 1958242952 to your indigo variable ID
            indigo.variable.updateValue(99148159, value=unicode(longitude))#change the 99148159 to your indigo variable ID
            retry = 0
            retry -= 1
            if retry == 0:
               indigo.server.log("[ERROR] Retrying to send the command")
                indigo.server.log("[ERROR] Failed to send the command")
    mow.logout()
Mon Sep 05, 2016 1:47 pm
Gusten offline
Re: Husqvarna Automower Script
And if you would like to use the output of the coordinates to make a plot you can see this post
viewtopic.php?f=165&t=16760
/Martin
Wed Apr 05, 2017 4:35 am
Gusten offline
Hi, Husqvarna have changed the API so this old script wont work anymore
I have a fix so if someone wants it just let me know
/Martin
Fri Jun 02, 2017 11:30 am
guenneguez_t offline
Petition for militating to have an official API ...
https://www.change.org/p/husqvarna-open ... usqvarana/
Fri Jun 02, 2017 11:53 am
Gusten offline
Done :)
Fri Jul 07, 2017 10:00 pm
kidney offline
Are the above script updated? it's not working for me!
Sat Jul 08, 2017 2:01 am
Gusten offline
No, i have the working script at home, will put it up during the week
Sun Jul 09, 2017 2:07 am
Gusten offline
Hi
Here are the new scripts
I am not very good in Python, so i have used trial and error to get this to work, i have used this https://github.com/chrisz/pyhusmow and made modification to the script
You will need to install configparser for the script to work
Don't forget to modify the script with your credentials and variable ID
Here are the script for collecting status and battery.
import json
import logging
import time
from configparser import ConfigParser
import requests
logger = logging.getLogger("main")
class AutoMowerConfig(ConfigParser):
    def __init__(self):
        super(AutoMowerConfig, self).__init__()
        self['husqvarna.net'] = {}
        self.login = ""
        self.password = ""
        self.log_level = 'INFO'
        self.expire_status = "30"
    def load_config(self):
        return self.read('automower.cfg')
    def save_config(self):
        with open('automower.cfg', mode='w') as f:
            return self.write(f)
    @property
    def login(self):
        return self['husqvarna.net']['login']
    @login.setter
    def login(self, value):
        self['husqvarna.net']['login'] = value
    @property
    def password(self):
        return self['husqvarna.net']['password']
    @password.setter
    def password(self, value):
        self['husqvarna.net']['password'] = value
    @property
    def log_level(self):
        return self['husqvarna.net']['log_level']
    @log_level.setter
    def log_level(self, value):
        self['husqvarna.net']['log_level'] = value
    @property
    def expire_status(self):
        return int(self['husqvarna.net']['expire_status'])
    @expire_status.setter
    def expire_status(self, value):
        self['husqvarna.net']['expire_status'] = str(value)
class API:
    _API_IM = 'https://iam-api.dss.husqvarnagroup.net/api/v3/'
    _API_TRACK = 'https://amc-api.dss.husqvarnagroup.net/v1/'
    _HEADERS = {'Accept': 'application/json', 'Content-type': 'application/json'}
    def __init__(self):
        self.logger = logging.getLogger("main.automower")
        self.token = None
        response = self.session.post(self._API_IM + 'token',
                                     headers=self._HEADERS,
                                     json={
                                         "data": {
                                             "attributes": {
                                                 "password": password,
                                                 "username": login
                                             "type": "token"
        self.logger.info('Logged in successfully')
        json = response.json()
        self.token = json["data"]["id"]
            'Authorization': "Bearer " + self.token,
            'Authorization-Provider': json["data"]["attributes"]["provider"]
    def logout(self):
        response = self.session.delete(self._API_IM + 'token/%s' % self.token)
        self.token = None
        del (self.session.headers['Authorization'])
        self.logger.info('Logged out successfully')
        response = self.session.get(self._API_TRACK + 'mowers', headers=self._HEADERS)
        return response.json()
        self.device_id = result[0]['id']
    def status(self):
        response = self.session.get(self._API_TRACK + 'mowers/%s/status' % self.device_id, headers=self._HEADERS)
        response = self.session.get(self._API_TRACK + 'mowers/%s/geofence' % self.device_id, headers=self._HEADERS)
        response = self.session.post(self._API_TRACK + 'mowers/%s/control' % self.device_id,
                                    json={
                                        "action": command
def create_config(args):
    config = AutoMowerConfig()
    config.load_config()
    if args.login:
        config.login = args.login
    if args.password:
        config.password = args.password
    if args.log_level:
        config.log_level = args.log_level
    if hasattr(args, "expire_status") and args.expire_status:
        config.expire_status = args.expire_status
    if not config.login or not config.password:
        logger.error('Missing login or password')
        return None
    if args.save:
        if config.save_config():
            logger.info('Configuration saved in "automower.cfg"')
            logger.info('Failed to saved configuration in "automower.cfg"')
    return config
def configure_log(config):
    logger.setLevel(logging.INFO)
    if config.log_level == 'ERROR':
        logger.setLevel(logging.ERROR)
    steam_handler = logging.StreamHandler()
    logger.addHandler(steam_handler)
    logger.info('Logger configured')
    retry = 5
    while retry > 0:
            mow = API()
            mow.login("användarnamn", "Lösenord")#Put your credentials here
            dic_info = mow.status()
            indigo.variable.updateValue(214675392, value=mowerStatus)#Change number to yours variable ID
            indigo.variable.updateValue(1295626237, value=batteryPercent)#Change number to yours variable ID
            retry = 0
            retry -= 1
            if retry > 0:
                print(ex)
                print("[ERROR] Retrying to send the command %d" % retry)
                exit(1)
    mow.logout()
And here are the script for different actions, this is the START script, and you need to change in the script depending on what you want to happen, you can use START STOP or PARK
import argparse
import json
import logging
import pprint
import time
import requests
    def __init__(self):
        self.login = ""
        self.password = ""
    @property
    def login(self):
    @login.setter
    @property
    def password(self):
    @password.setter
    @property
    @log_level.setter
    @property
class API:
    def __init__(self):
        self.token = None
                                     json={
                                         "data": {
                                             "attributes": {
                                                 "username": login
                                             "type": "token"
    def logout(self):
        self.token = None
    def status(self):
                                    json={
                                        "action": command
    if args.login:
    if args.password:
    if args.log_level:
        return None
    if args.save:
    return config
    retry = 5
    pp = pprint.PrettyPrinter(indent=4)
    while retry > 0:
            mow = API()
            mow.login("username", "password")#write you credential here
            mow.control("START")#Change to STOP or PARK if you like
            retry = 0
            retry -= 1
            if retry > 0:
                print(ex)
                exit(1)
    print("Done")
    mow.logout()
Mon Jul 10, 2017 8:07 pm
kidney offline
Thank will try it the minutes I'm done struggling with configparser!
Sun Apr 15, 2018 8:59 pm
deuan offline
Hello All,
Does this script still work. I have no idea how to get ConfigParser onto my computer, but I messed around and now I get a timeout error when running the script.
Error because embedded scripts execute sequentially they must complete their execution within 10 seconds.
Error modify the script to exit quickly or convert it to an external file (not embedded).
Stopping embedded script executor host (pid 32651)
Tue Apr 17, 2018 4:13 am
Gusten offline
Hi
Yes the script do still work.
I am running the scritp as a file not embedded. The script takes to long to run so it cant be run embedded.
When it comes to installing configparser did i found this
https://techglimpse.com/fix-no-module-n ... ort-error/
/Martin
Sun Oct 07, 2018 12:43 pm
Bollar offline
deuan wrote:
Hello All,
Use the instructions here to get ConfigParser installed: viewtopic.php?f=107&t=19129&p=158963&hilit=pip#p158963
sudo -s
curl https://bootstrap.pypa.io/get-pip.py | python
pip install configparser
Sun Oct 07, 2018 2:33 pm
Bollar offline
Is this script still working for you on Indigo 7.2?
If I run embedded, I get the following error:
   Script Error                    Error in plugin execution compileExecuteSource:
  File "plugin.py", line 209, in compileExecuteSource
  File "plugin.py", line 189, in _compileExecuteSource
  File "<string>", line 205, in _dynamicFunc
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site.py", line 360, in __call__
SystemExit: 1
If I call an external script, I get:
   Script Error                    Error in plugin execution executeFile:
  File "plugin.py", line 237, in executeFile
SystemExit: 1
Tue Oct 09, 2018 10:38 am
Gusten offline
Hi, mine is working and i am on 7.2 Iam running my script as files if it makes any differents?
