Getting state name from devices
Fri May 27, 2016 1:57 pm
Colorado4Wheeler offline
Is there a way to get state names from a device? For instance if I have a custom state called "foo" and have defined it in the plugin as "Value of Foo", is there a way I can read an indigo.devices device and pull that description out? Think triggers, when you pull up a device in the trigger list it doesn't show "foo", it shows "Value of Foo" and I would like to replicate that in my plugins so when I'm looking at device states I can present to the user the names of the states rather than the variable name itself.
I know that I can get the variable names from dev.states, is there a dev.statename or something like that? Or maybe a lookup "get name for state dev.states["foo"]"?
Fri May 27, 2016 2:28 pm
Re: Getting state name from devices
Great question. The answer though is that it isn't possible yet (from a plugin). We need to add it though...
Fri May 27, 2016 2:42 pm
You're looking for a way to get the <TriggerLabel> or <ControlPageLabel> of the device state definition?
You should be able to get what you want using the getDeviceStateList() method. See http://wiki.indigodomo.com/doku.php?id= ... in_guide&s[]=getdevicestatelist
Yes, Matt, I know it's not designed for that, but....
Fri May 27, 2016 2:50 pm
@FlyingDiver, I believe the request is to get it for any device, not just devices that your plugin defines. getDeviceStateList() is a callback method that's only called by the server within the context of a plugin.
This is one of those rare enhancements that I really want for a variety of reasons, but because it's such a PITA to implement, we keep kicking it down the road... :wink:
Fri May 27, 2016 2:59 pm
Matt & Jay, thanks for the update - and, yes, FD & Jay, I'm looking for it across the board instead of just for my own plugins. Isn't there a database query tool? I wonder if that could be a workaround until an actual function is built for it - or perhaps the ability to query the database either isn't really there or doesn't get deep enough into the database to get state names.
Fri May 27, 2016 3:08 pm
Yeah, the problem is it isn't in the database. Only the raw stateID's are stored there. The more verbose UI description is always retrieved by the Indigo Client directly before it shows the Trigger UI dialog by querying the plugin directly (via the getDeviceStateList() callback). So to fix this we need to cache off the information (in the database).
Fri May 27, 2016 3:09 pm
Ok, I missed that this was for any random device. You could make it work for any plugin device that you control, by adding code to add those labels to the device plugin props, but not for any other device. Bummer.
Sat May 28, 2016 6:52 am
I suppose it could be possible to do a simple XML read of the various plugin Device.xml files on the Indigo web server to parse the names for 3rd party plugins and build a Py function to resolve common non-3rd party plugin (such as knowing onOffState typically equals "On/off state". A bit of an undertaking and limiting but a possible workaround until there is something in Indigo 7 release 1 (evil grin).
It's not super critical, just a nicety so I totally understand why it gets back-burnered regularly.
