Getting something to run for X seconds
Thu May 19, 2016 4:22 pm
Colorado4Wheeler offline
I've had this ongoing problem that I'm trying to resolve where I put into a script to turn something on for X seconds and it will work when it's the only thing going but if there happens to be another Indigo command before or after it then it will only run for 1 second and quit.
For example:
indigo.device.turnOn(controller, duration=10)
When run on it's own with nothing else happening it will run for the 10 seconds and work properly, but if I have another device follow it then it will be somewhat random between 1 and 5 seconds before it quits. The obvious answer is "make this run by itself" or "don't control other devices afterwards" but I have 2-3 of these devices that each need to run for a few seconds at the same time.
I have tried:
time.sleep(10)
But that doesn't really seem to do anything.
Is there a proper way to insure that a device command gets it's full time span?
Thu May 19, 2016 5:54 pm
Re: Getting something to run for X seconds
Use a Timer to count off the delay, with a trigger for Timer Expired that turns off the device.
See http://wiki.indigodomo.com/doku.php?id= ... andpesters
You'll need to create the Timer device before the script runs. Or in it, I supposed.
