Editor for Python on Mac
Sun Sep 22, 2019 1:45 pm
mgolden50 offline
Re: Editor for Python on Mac
That would be great!
The key thing I'm looking for is how make indigo calls from a script in Bbedit. I tried what I thought should work but it didn't.
I entered the suggested command line in terminal but it was from the primary shell assigned to my Terminal app. Should it be something else?
Mike
Sun Sep 22, 2019 3:32 pm
You can't run Indigo Python scripts in a normal Python interpreter. For the moment, though, you can write your script in BBEdit, then copy/paste it into the interpreter window you get when you select the Plugins->Open Scripting Shell menu item.
After we ship 7.4, I'll investigate to see if there's any more direct way to run scripts from BBEdit (well, I know there is, but I want to check out the various alternatives).
Sun Sep 22, 2019 3:35 pm
mgolden50 offline
Mike
Sun Sep 22, 2019 3:48 pm
Sun Sep 22, 2019 7:47 pm
citysnaps offline
On the subject of Python program development, does anyone have recommendations for books, online courses, guides, etc for getting up to speed on Python? I've written software for a handful of languages over the years, but am looking for information and tools to help with the learning curve.
Brad
Urban photoblog: www.citysnaps.net
Mon Sep 23, 2019 3:40 am
When I first started using Indigo, I didn't know any Python at all. I watched YouTube videos from MIT Open Courseware and Google. Microsoft has just added a course but that may be too rudimentary for you, and there's always Kahn Academy. Since you have experience, I would recommend the MIT course which will scoot through the basics pretty quickly.
I also got answers to a lot of my questions on these forums and on Stack Overflow. I didn't find the original Python docs to be that helpful at first..
Mon Sep 23, 2019 8:08 am
mgolden50 offline
Jay,
I opened the scripting shell from the plugins menu and I get this:
Last login: Fri Sep 20 14:21:22 on ttys000
login: login: Could not determine audit condition
[Process completed]
The Terminal window won't accept any input.
Mike
Mon Sep 23, 2019 8:27 am
racarter offline
I found this book to be helpful:
https://www.oreilly.com/library/view/py ... 133354461/
Mon Sep 23, 2019 9:23 am
mgolden50 offline
Jay,
Now after opening shell I can't get the Terminal app to open with its normal login prompt.
Mon Sep 23, 2019 9:24 am
mgolden50 wrote:
Jay,
Reboot your computer. Also, check these posts:
https://stackoverflow.com/questions/424 ... -condition
https://www.reddit.com/r/osx/comments/a ... condition/
Mon Sep 23, 2019 9:29 am
mgolden50 offline
Thanks Joe. Duh
Mike
Tue May 31, 2022 8:00 am
Turribeach offline
What is the latest on this? Are we still unable to run Python scripts outside Indigo? I am using Visual Studio Code now which for the most part works fine although all the references to indigo.* are highlighted as missing. Anything I can do to improve that? Thanks
Tue May 31, 2022 8:05 am
Python scripts run fine outside Indigo. But you can't run a script that references Indigo (has "import indigo") outside Indigo. References to indigo require that the script be running in an IndigoPluginHost wrapper, as that's the only way for the script to communicate with the Indigo server.
What you can do is set up an action group that references an external Python group, edit that in whatever editor you want, and use the action group to run the script.
Tue May 31, 2022 9:11 am
If you just want to shut up the red warnings, putting this at the top may limit that to just one highlight:
    import indigo
except:
    pass
Note this has nothing to do with running scripts that reference indigo from VS Code (it can't be done as described above), it only shuts up the annoying highlighting.
Tue May 31, 2022 9:16 am
Turribeach offline
Thanks Joe, that's what I have been doing for now but I was wondering if anything has changed due to the move to Python 3.
And Thanks Jay, I like that little hack, one highlight my OCD can deal with. :mrgreen:
