Ping with OSX and Indigo
Tue Sep 12, 2017 6:11 am
ar26pt2 offline
Re: Ping with OSX and Indigo
For python newbies, here is an easy script to ping two related devices and output each as as a true/false variable . true=response within 0.5seconds (adjust the -W parameter to make this timeout shorter/longer). And of course replace the ip's and variable names with your own. This seems cleaner than the applescript I was using for ping.
import os   # this is needed for ping command
indigo.server.log('Pinging Camera & NVR now:') #optional add event log entry
# Ping my NVR appliance, update variable, publish failure to event log
response = os.system("/sbin/ping -c 1 -W .5 192.168.1.100")
if response == 0:
 indigo.variable.updateValue('PING_camNVR', 'true')
 indigo.variable.updateValue('PING_camNVR', 'false')
 indigo.server.log('   NVR not responding')
#Ping my camera, update variable, publish failure to event log
response1 = os.system("/sbin/ping -c 1 -W .5 192.168.1.101")
if response1 == 0:
 indigo.variable.updateValue('PING_cam1', 'true')
 indigo.variable.updateValue('PING_cam1', 'false')
 indigo.server.log('   Cam not responding')
#Report to log that both are working
if response+response1+response6 == 0:
 indigo.server.log('   NVR + Cam responding')
Tue Sep 12, 2017 8:57 am
Nice. One suggestion: you probably want to use variable IDs rather than variable names so if you change the variable name the script will continue to work.
