my first python, need some help
Tue Jun 23, 2015 9:56 pm
jlTech offline
hello
need some help with my first python script. I suspect i have done it wrong but i cannot find the error....
Trying to upload current temp to a website (temperatur.nu)
import httplib, urllib
curTemp = indigo.devices[1204901047].displayStateValUi
id = "6488954"
city = "hofors"
params = urllib.urlencode({'s': city, 'id': id, 't': curTemp})
headers = {"Content-type": "application/x-www-form-urlencoded", "Accept": "text/plain"}
conn = httplib.HTTPConnection("www.temperatur.nu:80")
conn.request("POST", "/rapportera.php?", params, headers)
response = conn.getresponse()
print response.status, response.reason
data = response.read()
indigo.server.log(data)
conn.close()
# just some logging to see what i got
indigo.server.log(str(curTemp))
indigo.server.log(str(conn))
indigo.server.log(str(params))
here is the response i get. I suspect it is the connection string that is wrong some how. Translate first row (Fatal, failure! Could not match city and id) :)
Script                          Fatal, failure! Kan inte inte matcha stad och id!
  Script                          10.5
  Script                          <httplib.HTTPConnection instance at 0x5e3dc88>
  Script                          s=hofors&id=6488954&t=10.5
Tue Jun 23, 2015 11:31 pm
Re: my first python, need some help
My Swedish is non-existent, but two points to note:
1) That's the same error you get if you go to rapportera.php in a browser without any values
2) The example URL in the wiki shows two parameters called hash and t, and it says you will get given a hash key when you register your interest
If I was diagnosing this from scratch I'd be wondering if you need to remove the ? from the conn.request line?
Tue Jun 23, 2015 11:56 pm
jlTech offline
This URL is working in my fibaro using lua.
Did try without ? but same error
Regards Jonny Larsson
From my iPhone6+ med Tapatalk
Wed Jun 24, 2015 12:57 am
jlTech offline
This work so i think it is something with the params row
id = "6488954"
city = "hofors"
conn.request("POST", "/rapportera.php?s=" + city + "&id=" + id + "&t=" + curTemp, params, headers)
indigo.server.log("Temperatur updated " + data)
conn.close()
Wed Jun 24, 2015 5:18 am
RogueProeliator offline
Not sure if this is your issue, but you seem to be sending the data twice -- once on the URL query string and again in the body of the request. If you continue to include it in the query string you really should URL Encode it, though as long as you know the exact city/ID that will be passed it then it may not be an issue.
Adam
Wed Jun 24, 2015 5:23 am
jlTech offline
When i did change from
to this it works.
Perhaps not a good script, its my first so.... :?
Wed Jun 24, 2015 8:34 am
Your URL line (with params) looks like a GET, not a POST. Are you sure it's a POST? Also, in your original script, you don't need to urlencode the params since it's going as POST data. If it does accept a POST, then that's what's wrong there. And the url should just end with the .php (no ? or params).
