Airfoil & iTunes Control
Sat Nov 29, 2014 2:29 pm
OnnoH offline
I'd like to share a piece of Indigo Python code with you.
I have several Airplay devices around the house and started to use Airfoil to activate them after they're turned on. Sending a play command to iTunes works fine. If already playing the command is simply ignored. Pausing however should only occur if there's no other device still active. I came up with the following server side script in an action group:
indigo.server.log("Action Group: Pause iTunes")
noPlaying = 0
connectedValue = "connected"
airfoilName = "Airfoil"
libraryName = "My Library"
if itunesPlugin.isEnabled():
   folderId = indigo.variables.folders[airfoilName].id
   libraryId = indigo.devices[libraryName].id
   for var in indigo.variables:
      if var.folderId == folderId and var.value == connectedValue:
         noPlaying += 1
   if noPlaying > 1:
      indigo.server.log("Still playing. Let it be!")
      indigo.server.log("All quiet. Stop the music!")
      itunesPlugin.executeAction("pause", deviceId = libraryId)
   indigo.server.log("No iTunes! What am I doing here?")
It seems to get the job done. What do you think? Any pointers? Am I missing something? As I'm always on the lookout to improve, comments are appreciated :wink:
Wed Dec 10, 2014 3:44 pm
OnnoH offline
Re: Airfoil & iTunes Control
Expanding (and renaming) my own post :)
Googled for an Airfoil/iTunes/Airplay issue and came across this thread http://forums.indigodomo.com/viewtopic.php?f=18&t=9100&p=65182&hilit=airplay#p65182
Sometimes Airfoil complains it cannot connect to a speaker, because it's in use. Very frustrating if this happens when the bedroom amplifier, scheduled to wake us up with lovely iTunes music, stays quiet :x
It seems that either my Apple TV connected to an Onkyo TX-NR616 or Denon Amplifier DRA-N5 (the wake up caller), claim possession of the Airplay setting in iTunes. This is maybe what's causing Airfoil failing to connect to that particular speaker.
Therefore I put the following AppleScript in an Action Group executed in other Action Groups.
tell application "iTunes"
   set current AirPlay devices to AirPlay device "Computer"
end tell
Hopefully this will result in a reliable alarm clock 8)
