using subprocess.Popen + kill in indigo
Wed Mar 26, 2014 8:21 pm
issue with p.terminate() in indigo python:
when starting a process with
p = subprocess.Popen( ....)
then trying to end the process with
p.kill() or p.terminate() gives an error message that p does not have the terminate method
It does not work in python 2.5
you need to use
os.kill( p.pid, signal.SIGKILL)
naturally one has to
import os, signal
The terminate method works in python 2.6 and higher
Just FYI incase you spend some hours trying to make this work..
